Wooden Bandsaw
  • Shep
    • Nov 2008
    • 710
    • Columbus, OH
    • Hitachi C10FL
    Wooden Bandsaw
    I know most people have posted articles about this guy in the past, but I thought you would like to check out his newest project; building a wooden bandsaw.
    http://woodgears.ca/bandsaw/wheels.html
    -Justin
    shepardwoodworking.webs.com
    ...you can thank me later.
    Good for him! That is an undertaking, but if successful, he will be able to have quite a setup for a very minimal investment. I am curious on how he expects to build the post? The tensioning of the blade puts so much stress on the post (AFAIK, not owning one myself yet) that I would believe him to be hard pressed not to buy some steel column.
    • Shep
      • Nov 2008
      • 710
      • Columbus, OH
      • Hitachi C10FL
      Knowing him, He'll probably make it out of wood. But who knows, I'm sure he'll engineer it to be strong.
      -Justin
        Is wheel construction intrigues me.
        I wonder why he didn't just laminate two pieces of plywood together.
        The method he used seems to add quite a bit of complexity, and with it a greater chance of balance problems. Not sure what it buys him.
          • 22085
          Good for him! That is an undertaking, but if successful, he will be able to gave quite a setup for a very minimal investment. I am curious on how he expects to build the post? The tensioning of the blade puts so much stress on the post (AFAIK, not owning one myself yet) that I would believe him to be hard pressed not to buy some steel column.
          There are kit built (Gil-Built) wooden bandsaws that had arms strong enough (or so I presume). I'm sure he could build one fairly stiff to take the load... it might be larger than a cast iron neck though...Additional width, thickness, and angle bracing I don't see as a limiting problem.
          its quite a bit lighter since the overall thickness is less in the center, it also moves the mass concentration to the outside.
            Good point about the mass at the outside being desirable.
            I guess it is also possible that two pieces of plywood may result in separating plys when you're trying to stretch the tires on.
            • Shep
              • Nov 2008
              • 710
              • Columbus, OH
              • Hitachi C10FL
              Just wanted to let you guys know that he decided to make his post out of wood like I thought he would. Amazing.
              http://woodgears.ca/bandsaw/build.html
              -Justin
                I have a Gil Built 12 inch bandsaw. It works OK. The wheels are aluminum with rubber wheels. It uses blades meant for a 12 inch Craftsman. The column is 3/4 plywood with a piece of construction lumber. It flexed enough I added an oversized piece of 2X construction lumber. It still flexs some. But it cuts. I don't use it a lot. If I had a big project, I would probably buy a new saw. I've made 12 kitchen chairs with curved backslats cut on this little saw. 4 of the chairs have two large backslats that are 4 inches tall out of oak. That was a lot for my little saw to cut and the cuts were not very smooth but it did it.
                  That is really cool. I am kinda suprised that he didn't have the capability to cut keyways? I should think a hacksaw would make quick work of that, the author seems very accomplished.
                  • PhilofKayDu
                    • Aug 2009
                    • 60
                    • Northern Indiana
                    Wooden Bandsaw
                    I have built some tools and jigs in my time. I thought my ideas were clever for what I needed them for. But,OMG, a wooden bandsaw! Very very clever!!!! Phil
                    • Jack Bench
                      Amazing, simply amazing.
