Help selecting a new tablesaw
  • Cubsfan
    • 164
    • CO.
    For various reasons, I've kind of fallen out of love with my BT3100, and am planning to get a new table saw. I have about 1/2 of a garage to keep things in, but am still trying to keep things at least able to be packed away, so mobility is very high on the list.
    Anyway, my current contenders are:
    http://www.sears.com/shc/s/p_10153_1...?keyword=21833
    - About $370, which is quite nice. The build quality isn't rock solid from reports, but it sounds like a good option.
    http://www.grizzly.com/products/SHOP...ble-Saw/T21853
    - About $519 + $70 for a mobile base ~= $600
    http://www.tools-plus.com/delta-36-980.html
    - About $700
    Any thoughts about these three. I'm really leaning toward the sears one mainly due to price. If I look at either of the other two the purchase will probably be put off for a decent amount of time.
    Thanks for any insights!
    If the need is not immediate I would consider the two higher priced options. Either of those should last a good long time and my guess is you will be glad you waited to get them. Another option is to watch the classifieds, craigslist, etc in your area for one you could restore.
    • natausch
      • Aug 2009
      • 436
      • Aurora, IL
      • BT3000 - 15A
      Personally I'd wait a few months until the major wood shows start up again. Right now there is a "dearth" of hybrid/contractors saws that meet the requirements of a secondary saw in a professional shop or a higher end amateur shop.
      • Knottscott
        • 3815
        • Rochester, NY.
        • 2008 Shop Fox W1677
        The Delta and Grizzly are very similar under the hood, but the Delta has cast iron wings, and a built in mobile base (a mobile base can be added to any saw). Grizzly has other versions of that saw with cast iron wings too. Both are the older style contractor saws with the motor hanging out the back. Both have very nice steel t-square fences.
        The Craftsman 21833 is more of a hybrid saw with the motor moved inside the enclosure, which has a smaller footprint, shorter drive belt, better dust collection, and no "lifting" hazard when the motor is tilted. The 21833 also has a riving knife and a built in mobile base. It also has steel wings. There was a good discussion on it here. Here's an owner review on Lumberjocks.
        The granite top Craftsman 22116 hybrid has been on sale for < $700 last week, and would have more appeal to me than any of these, though I'm less certain about the granite top. It's made by Steel City and has a riving knife, cabinet mounted trunnions, steel t-square fence, and a full enclosure. You might also find a clearance deal on the 22124 hybrid. The Steel City 35920 and 35930 are similar.
        If you've got 220v, you might want give some consideration to this Central Machinery 93380 3hp cabinet saw. I've never seen one, but from the manual it looks similar to many of the Asian import cabinet saws. Not my favorite brand, but I've had good luck with some select HF tools, and this looks like a lot of saw for the money. There's a good review and discussion on it here.
        A good used saw is always a viable option for maximizing your budget.
        • master53yoda
          • Oct 2008
          • 456
          • Spokane Washington
          for me I'd go buy the bt3version from sears and put it on a built up base. it can't be beat for the price and non commercial use.
          my 2 cents worth.
          Art
            • 22106
            my 2 cents worth.
            Master Y, in all your wisdom you must have missed the part where the O.P. says he's fallen out of love with his BT3000.
              What about the Ridgid 4511? Granite top and a 1 3/4hp motor, not bad for the $$, certainly a hybrid, has a Riving knife.
              • Knottscott
                • 3815
                • Rochester, NY.
                Great deal if you can still find one, but they discontinued them and closed them out for $299....worth a look but prolly not many left.
                  I want comment on any of the contractor saws since it has been many years since I had one but.. I will comment that it would be a cold day in Haiti before I payed $700 for a contractor saw. I sold a factory re-conditioned (new motor.. table completely re-ground.. new trunnions.. Biesemeyer fence) Uni-saw for $825. There are cabinet saws listed used from $600-$900 often in my area. $700 for a new contractor just isn't appealing to me personally.
                  You would be wise to be patient and look around since you have a saw at the moment in lieu of jump on the first impulse you have.
                  Good luck...
                  • JSUPreston
                    • 1189
                    • Montgomery, AL.
                    Sarge is right about the pricing. I paid $440 for my Delta 979 contractor saw (same base saw as the O.P. posted, without any fence) + $80 & tax for the Bies fence when Lowe's was clearing them out a few years ago. For about $550, I have the same saw with IMHO a better fence than the 980 saw has. In effect, I have the 982 model.
                    If you can manage it financially and space wise, you may be better off with a used Uni or PM66, etc. I would have gone that route, but I'm not sure that putting a Uni in my shop would work out well, given the floor where the "982" is.
                    • Cubsfan
                      • 164
                      • CO.
                      Thanks for the help everyone. What if I added this one into the mix:
                      http://www.grizzly.com/products/10-T...t-Wings/G0444Z
                      Can anyone help me out comparing that one to the others, specifically the delta?
                      Thanks!
                        I haven't used either saw, but the Grizzly appears to be more saw for less money. Fence is longer - 42" vs 30" IIRC. Table is more or less same size although the Delta lets you rip 13" to left of blade, Grizz is only 10". Grizz motor is bigger, at least it is rated for more HP. Of course this could just be the rating on it. Both are 240/120V capable. Grizz comes prewired for 220V which I actually prefer. The Grizz is also heavier which implies better construction, at least to me. Grizz fence is also a Shop Fox fence. If it were me, I would buy the Grizzly. Both saws will do what you want, the Grizz will do it for less money.
                        • BrazosJake
                          • 1148
                          • Benbrook, TX.
                          • Emerson-built Craftsman
                          I'll have to join Sarge's dogpile on the $700 contractor saw. If you've got that kinda money to spend, go a couple or three hundred extra and get a cabinet saw. If you're space-challenged, the footprint is actually smaller since the motor isn't sticking out the back.
                          • Cubsfan
                            • 164
                            • CO.
                            Ok, one more
                            Turns out I can still get a G0444 for around $545 shipped. Any thoughts about how that one compares to the shopfox one?
                            As far as the cabinet saw, I could get one, but that's really getting too expensive for my budget. The $700 option is already really pushing the budget to the breaking limit, so adding 'just' another few hundred pretty much breaks it. Especially when I compare it to the more budget-reasonable saws around $500.
                            Thanks still for all the help!
                            • Knottscott
                              • 3815
                              • Rochester, NY.
                              Shop Fox and Grizzly are sister companies, and are often very similar tools. SF carries a longer warranty.
                              In this case, the SF is the same as the former Grizzly G0575, which was the left tilt equivalent of the Grizzly G0444. The G0444"Z" ups the motor power and adds cast iron wings...the G0576 was the left tilt equivalent of the G0444Z. The fence on all of these is the SF Aluma Classic...steel t-square design with aluminum faces...similar to the Biese Homeshop fence. If you don't mind right tilt, the extra power and cast iron wings for $70 is money well spent IMHO. Both are still the older style contractor saws with table mounted trunnions, connecting rods, and an outboard motor.
