I am planning on making my own router table extension for my table saw.
I have a few questions regarding the fence/table and router mount.
For the fence, I was on using a 6" high piece of plywood with a t track on the side about 4" high (from the bottom). I was going to use two 3/4" layers of plywood plus one 1/2" sandwiched to provide enough space for a 3 1/2" raised panel bit. I will mount this wooden fence to my table saw's rip-fence. Does this plan seem ok? Should I have a top track? I'm thinking most featherboards and hold downs could mount to side track?
As for the table, I was going to make out of plywood and use one t track piece about 8" from router shaft... is this a good distance?
Finally, I'm not sure howto mount router (I have a ryobi plunge). I used the mounting plate that came with BT3100 kit with that table. For my new saw, I'm going to try and reuse that plate into plywood by routing out the thickness of that plate to make it flush. Sound right?
I'd appreciate any thoughts.
