I'm 98% positive that in 110/120v the wide blade is the neutral
Is my 220 volt outlet wrongly wired?
How stuff works agrees:
http://electronics.howstuffworks.com/question110.htm--------------------------------------------------
Electrical Engineer by day, Woodworker by nightComment
Youre probably right, I always have to look it up.
However I always check them both.
In my experience with manufacturing groups (and human nature) when there's two ways to put them together and they can fit either way, even when clearly marked and illustrated the average human assembly worker will put approx 1% of them backwards.
In an assembly line situation several times, where we had products with a red wire and a black wire to be soldered to two terminals one clearly marked with a dot, or in another case, with a wide solder terminal (the other was narrow), I had post assembly tests run and over a large number of samples, just over 1% randomly distributed (each assembly had 128 pairs of joints) were consistently backwards.
I think this applies to any process where two items are put together with a clearly marked visual index but can fit together either way equally easily. That includes wiring a socket where you have a white wire thats supposed to go to the silver terminal and a Black wire that supposed to go to the gold terminal but they fit equally well the other way around. And you have an electrician doing about 100 of these a day to finish your new house.
So in a house with 100 outlets (I assuming this is an average) you might find 1 outlet backwards (neutral and hot swapped). I have one of those three-light indicators that shows at a glance which terminals have voltage between them. In my first house, I had one outlet wired backwards - the one behind the refrigerator. In my second house, I think i had one but I don't recall offhand which one.
That's why you never depend upon the neutral being at zero volts.Last edited by LCHIEN; 02-02-2010, 07:16 AM.
LCHIEN
