Belt tension system for band saw base
  • steve_b
    • 47
    • Mississauga, Ontario, Canada
    I am currently building a mobile base for a band saw. The band saw is a 40/50's vintage 14" 'Beaver" (Delta?) that I purchased with no motor or base (not quite true - it had a spindly wood 'stand' with a 1/3hp motor nailed to the wood)..
    I am looking for suggestions as to mounting the motor and creating a belt tension system. I have a small table saw (not currently using) that I got from from my grandfather that used the motor weight for belt tension - I always found that this vibrated (even with careful alignment of the pulley)
    Since I have a 1hp motor to go into this 'base' would the pivot and weight system be the best way - or some form of fixed mount?
  • billwmeyer
    • 1868
    • Weir, Ks, USA.
    I am about to change over a stand to a homemade stand. I plan to just slot some plywood for the motor to mount on. Sliding the motor on the slots to tighten the belt.
      I would think you want some kind of slotted carrier to adjust and lock the tension.
