band saw blade length
  • jussi
    • 2162
    Looking to get a new blade for my BS. It's a Delta 28-243F. What length should I be getting? Can't seem to find the manual online. Should I simply measure the current one? The increments for different blade lengths seem to be pretty small and I don't want to be off by a little in my measurement and order the wrong one.
    looked at the pictures/parts list on the net... 28-243 is a 14" cast iron frame bandsaw from the 80's and is based on the standard Rockwell/Delta design.
    i think you'll find all those Delta 14" bandsaws with cast iron frames take 93-1/2" blades.
    • pbui3057
      • Jul 2008
      • 114
      • Mather, CA
      I think that most 14" bandsaws use 93.5" blades unless you have a riser block..
      • headhunter636
        • 161
        • Federal Way, WA
        • Ryobi BT 3000
        Or you bought a Craftsman, then it takes an off the wall 99 3/4.
        Dave
        BT3000
        "98% of all statistics are made up"
        • toolguy1000
          • Mar 2009
          • 1142
          • westchester cnty, ny
          whatever you want to know about delta 14" band saws, contact lou iturra @ iturra design, 904-371-3998. extemely knowledgeable about band saws, especially delta band saws.
            Measure the old one with a string or sewing tape in lieu of guessing...
            • headhunter636
              • 161
              • Federal Way, WA
              • Ryobi BT 3000
              I found this, it may help. It isn't the "F" model but have a look anyways if you want.
              http://goldmachinery.com/machinery/9945.htm
              Dave
              BT3000
              • Al R.
                • Sep 2009
                • 111
                • Florida.
                • Delta 36-600
                Yes, it should be 93" 1/2. If it has a Riser Block it will be 105".
                "The course of history shows that as a government grows, liberty decreases"....it happens the same with a big shop.
                  Jussi,
                  Not sure what type of blade you are looking for but I have a standard 93 1/2" blade just lying around my shop unsed. This was the blade that came with my PM bandsaw but as I got the riser and it went on immediatley its never been used. IIRC its a 3/8
                  • Al R.
                    • Sep 2009
                    • 111
                    • Florida.
                    • Delta 36-600
                    [QUOTE=poolhound;431813]Jus
                    I have two 93 1/2 as well and they are posted at amazon.com for sale: one is Timberwolf (1/2 inch) and the other Olson All Pro (1/8 inch wide). I had the same situation, the order arrived when I already had added the Riser Block to the BS.
                    • Dan Tipton
                      • 8
                      • Grafton, NY
                      And to check yourself, calculate it yourself --
                      2 * 3.14 * wheel radius + 2 * the between the 2 wheel axles
                      This will give you an "average" length -- I would try the standard blade that is closest to my calculation.
