I Picked Up the HF Multitool Today
I put a piece of stick-on sandpaper on the blade where it clamps on, and my old version without the pins holds its blade securely. With this Bosch bimetal blade:
http://www.mcfeelys.com/product/RBB-...nge-Cut-Blades
it works perfectly for cutting nails to remove clapboard siding when you don't want to risk destroying the board by prying it off.AlanComment
I grabbed one for $30 the other day. First task was cutting drywall for removal, and it worked like a charm.Happiness is sort of like wetting your pants....everyone can see it, but only you can feel the warmth.
I think you all have made me want to spend some cash.
I may not need it often but for the price if it's used once it will be worth the price.I think therefore I .....awwww where is that remote.Comment
Oh, cool! I didn't know Bosch made a blade for these tools. I've got one of the old-style Feins, and my main complaint has been the exorbitant price of replacement blades. These tools are great for making a scarf joint to replace a segment of rotted trim. I start the cut with a circular saw set at 45 degrees, then complete the cut (the part of the cut that you can't get with the circular saw, without cutting into the window) with the Fein. It will cut through nails, too, with the bi-metal blade.I put a piece of stick-on sandpaper on the blade where it clamps on, and my old version without the pins holds its blade securely. With this Bosch bimetal blade:
it works perfectly for cutting nails to remove clapboard siding when you don't want to risk destroying the board by prying it off.Comment
Just a reminder to those who get Wood, American Woodworker (maybe others) - HF has ads now in those, and they have a coupon in the add for MF tool for 29.99.
Also, I own one now, and have used it for some plunge cuts that really no other tool would have done well, and have some grout removal planned for it as well. For these types of things, the tool is really indispensable.Last edited by Bill in Buena Park; 09-25-2009, 10:42 AM.Bill in Buena ParkComment
I think Alan was saying the Bosch blades will fit the HF tool...not that they will necessarily fit the Fein tool.Oh, cool! I didn't know Bosch made a blade for these tools. I've got one of the old-style Feins, and my main complaint has been the exorbitant price of replacement blades. These tools are great for making a scarf joint to replace a segment of rotted trim. I start the cut with a circular saw set at 45 degrees, then complete the cut (the part of the cut that you can't get with the circular saw, without cutting into the window) with the Fein. It will cut through nails, too, with the bi-metal blade.
I did find a site once where you could buy replacement blades that would fit the Fein (they were being fabricated by someone out of their metal-working shop), but I can't find the link. They were still pricey and of limited selection, though not as much $$ as actual Fein blades.
I'm kicking myself because I bought a Fein for my dad a couple years ago...about a year before Fein's patent apparently expired. Now, everyone makes one!Mike
Drywall screws are not wood screwsComment
"These Bosch accessories may also be used on the Proxxon tool and the “old style” (non-star drive) Fein tools." -from McFeely's website...
...I guess the only way to be sure is to try.Comment
