I had a slightly to slightly serious vibration issue last time I used my new to me bandsaw. I went through all the normal causes this evening starting with a possible bent axle considering the hit this machine took on top with the previous owner. The wheels and tires are within .002"-.004". Next I checked that the wheels were balanced and although my first three spins all landed within 2" of the same spot when it came to rest, the next several were all random. Then I noticed that the upper wheel seemed to be wobbling like a hula dancer. So I rigged up my dial indicator to check that and it shows the upper wheel as having ~.030" wobble to it. That seems excessive. The lower wheel is within a couple of thousandths. So it seems I found my problem unless someone else comes up with anything else or disagrees?
When I pulled the belt off to check the balance on the lower wheel it did not seem to have any memory but I am going to pick up a link belt for it anyway I believe. I will be in Woodcraft next week to pick up a special order so I can get it then if they have a reasonable price. The special order is a 1 micron upper bag for my dust collector to replace the fine dust spreader that is on there now and two boxes of plastic lower bags. Should be quite an upgrade and if anyone has a 1hp Delta dust collector they have the upgraded bags for $20.
Also, Kreg sent me the replacement knob for the fence I added very quickly. It was here within a couple of days so not only did they make it right, they were very speedy about it.
