Belt/Disc Grit Preference
  • sweensdv
    • 2873
    • WI
    • Baileigh TS-1040P-50
    For those of you with belt/disc sanders, what grit of paper do you run? Do you use the same grit for both the belt and the disc?
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    I use 80 and 120 grit on my belt and disc sanders. I prefer a coarser grit on the disc.
      Does belt / spindle count?
      I have belts and sleeves in 80, 120, and 160. (Trying them out).
      I find 80 FAR too aggressive on the belt, but okay on the spindle with a light touch... 120 and 160 on the belt. 120 is great for fast stock removal, 160 leaves a pretty smooth finish that I finish off with a 220 grit sponge.
      Rats, this thread reminded, me, I need to get to HF to stock up on sanding sponges...
        For either it would depend on how smooth you want it, and how slow you can run the tool. For general shaping I wouldn't go smoother than 80x. For finish work 120x to 150x maximum. I wouldn't use a belt or disk for work to be stained or film finished. A ROS, scraper, or by hand would give better results.
          I generally run 120 on my stationary disk/belt sander and I run 80-100 on the handheld belt sander. The handheld I use for fast stock removal - sanding off stain, etc and then I do a finish sand with a ROS. The stationary sander I am usually doing final shaping, cleaning up mitres, etc.
