Belt Sander...
  • steve_b
    • 47
    • Mississauga, Ontario, Canada
    Belt Sander...
    Looking for recommendations on a belt sander. General home and project use.....can I mount to a table? (on it's side?) so I can 'profile' shapes (if this is what it is called) or lay on it's back for smaller parts (if possible).
    Suggestions?
    Regards
    For doing the "flat sanding" on a table as it seems you are talking about, I would say look into the Ridgid EB4424 oscillating edge belt / spindle sander...
    For handheld use... Not sure. Don't currently have one. Been drooling over the Bosch and Hitachi models though. The Ryobi seems okay, the B&D and Skil seem to get lots of bad reviews...
      Having had several brands, I would recommend Porter Cable. I have 3"x24" and 4"x24", and use the 3" mostly. They can be clamped/supported for bench type use, but you have to make sure the belt clears, and it won't come loose. That type of use isn't outlined in the owners manual.
      • tseavoy
        • May 2009
        • 200
        • Nordland, Marrowstone Island, Washington
        • Older 9 inch Rockwell Delta (1960?)
        I have a Sears 3"X21" belt sander I have had for years. I guess you could clamp it down. If you just put the handle in a vise, the vibration will loosen it.
        I have no complaint with the Sears.
        Tom on Marrowstone
        • Knottscott
          • 3815
          • Rochester, NY.
          • 2008 Shop Fox W1677
          I've been pretty happy with my Hitachi SB75B. ReconSales has it for $61 minus 25% thru Father's Day.
          • Sawatzky
            • 359
            • CA
            Porter Cable for sure! I have the variable speed 3x21". I bought it used and the variable speed option does not work too well, but I don't really see a need for it. Great sander, and it tracks very well.
            • tfischer
              • 2349
              I have it. I love it. It gets used in just about every project (be it a shop jig or something 'real') I do...
              • vaking
                • 1428
                • Montclair, NJ, USA.
                • Ryobi BT3100-1
                I have a Ryobi 3x21. It is the same sander that was sold some time ago by Sears under Craftsman name. It has flat top, so you can put it upside down on a bench and use as stationary belt sander. Also it has some threaded holes that can be used to mount it in various positions if you make a base for it. I made a primitive holder and now can mount it in any positions in a vise. If I want to get inventive I can probably make a tool rest for it as well. So far did not have the need.
                Alex V
                  I have a 3x24 Makita that I clamp to my work bench with bar clamp( rubber ends). I get by using it on edge to sand shapes. To do this I have a 12 x 18 plywood( roughly) that is clamped to the work bench. The sander is clamped down to this board. In front of the sander is another board ( attatched to the bottom board) to use as a table. It raises your work to the height of the sanding belt.
                  It's not perfect but then I don't live in a perfect world either.
                    I have used and owned several different model/brands. When my last Craftsman bit the dust (spun a bearing and destroyed one side of the plastic housing, which can't be bought as a replacement part) I bought a PC 352VS.
                    This is a 3 x 21 sander that is hands down the best sander I have ever used. A well balanced sander. The metal body makes it durable and gives it enough weight that it will work a horizontal surface with no downward pressure added yet light enough that you can work on a verticle surface without wearing your arms out. This will likely be the last belt sander I will ever buy.
                    • steve_b
                      • 47
                      Thanks for the notes, I'll try to find who might carry the PC 352VS in my neck of the woods (Ontario Ca.)
                      • mpc
                        • 1018
                        • Cypress, CA, USA.
                        • BT3000 orig 13amp model
                        Anybody have any comments on this combination?
                        DeWALT sander plus frame stand
                        I noticed it while walking the isles of my local Woodcraft. I've never really looked at it since I have a belt sander and the Ridged EB4424 oscillating belt+spindle sander.
                        mpc
                        • germdoc
                          • 3567
                          • Omaha, NE
                          • BT3000--the gray ghost
                          I am a big fan of the Bosch 3x21. I was going to write an ode to it in fact, because it is my favorite "unsung" tool--nothing fancy, but I use it on virtually every project.
                          It is extremely well-balanced and fairly light weight--can sand flush with no problem. From time to time I clamp it to my workmate to use as a stationary sander. It is not a power hog, so I wouldn't use for massive removal of material, but it is perfect for the cabinetmaker. The platen is very flat. Dust removal is very good, as well.
                          There is a stand and fence available for it that I haven't felt the need to get yet. I got my reconditioned for (as I recall) a bit over $100. Highly recommended.
                          Jeff
                            Thanks for the suggestion. I find the 3x21 easy to handle, but I prefer 3x24 and 4x24 (PC brand).
