I picked up one today. My local HF had dozens on the shelf. $39.99 and they took the 20% coupon so ~$34 OTD.
HF Multifunction Tool Update
techzibits.com -
I have another update. I used the tool this weekend to cut out a portion of drywall that needed to be replaced/ patched. Cut like a dream, and much less dust dispersing than a dremel/ rotory saw.
I'm hooked.Comment
All you who own and have operated this, if I were to buy it, what other attachment should I pick up at the same time? Or does it come as a package?
Say I'm interested in cutting door jambs, taking out one broken tile from the patio by cutting around it, trimming a piece of indoor floor-tile (protrudes into the room where wood flooring is), and cutting dry-wall to put in a power-socket?It is the mark of an educated mind to be able to entertain a thought without accepting it.
- AristotleComment
I am completing a room remodel where this tool had relatively big part. The tool worked fine for cutting door jambs and notching wood. It also did OK on grout removal even though I did not have diamond blades and used semi-circle blade. It cut drywall better than my rotozip. It did not do well on a nail that I accidentally came accross. In my opinion it is a good tool although metal seems to be out of its reach. Most important blades in my opinion are semi-circle and straight. Diamond blades will probably come in handy too for tough grouts in the future. So far I have not used it for any sanding.Alex VComment
radhak,
They didn't have any when I was there, but they sell the diamond/ grout blade seperately. With the kit comes a scraper, sanding pad, and a few straight blades. I'd say it's not a bad deal to pick up their blade/ scraper set that they have there as well ($8, I think).
As far as the tool not doing metal well, I think that's a function of the blades, not the tool. The tool's function is such that there really isn't too much of a chance that it's not working properly as long as it's working (in my opinion, I'm no mechanical engineer).
I think if you could buy the more $$ Dremel, Rockwell, or Fein blades and use them on this, you'll have similar results (anyone tried this??).Comment
Does anyone know whether Bosch blades fit the HF multitool? I want to use it for cutting nails to remove some wood siding on my house in such a way as to be able to replace it. (The nail heads pull through the cedar if I pry them off.) The HF diamond blades are never in stock, but Bosch has bimetal blades that look like the right thing to use, and they are reasonably priced:
http://www.mcfeelys.com/product/RBB-...nge-Cut-Blades
It looks like they might fit, but all the different brands seem to use different looking attachments.AlanComment
I suppose I might as well add this here: the Bosch blades work well, and cut nails very easily without dulling. I have an older version of the HF tool without pins, and put some stick-on sandpaper on the blades. They lock down without slipping.AlanComment
That's good news. The HF store near me never has them in stock.
.Comment
Thanks for this tip. My version doesn't have pins either, and I have had a problem with the blade slipping. Does the latest version have pins?Comment
