sharpening hand saws
    I have quite a few very old tools in my collection that I inherited from my grandfather. Some may be officially antiques as I was about 20 (am now 49)when he died at the age of 90 something.
    I have 3 saws (one is a nice tenon saw) and while they do work they are not very sharp. I would like to restore them but have never tried to sharpen a hand saw. I guess I could send them out but would like to try and do it myself if its not too tricky.
    So folks any advice would be warmly welcomed.
  • williamr
    • Dec 2006
    • 56
    • Mazatlan or Toronto
    • BT3000SX
    My dad used to sharpen his own saws.
    He had a saw vice and a collection of triangular files (coarse, medium and fine), and a tool to correct the "set" of each tooth for Setting the kerf of the balde. Forget the name of the tool. Rip saws -- not much set, cross cut more -- as I recall.
    File the saw sharp, then correct the set by sighting down the blade -- that will work too -- assuming the majority of teeth are still set correctly.
    I think you can get books at Lee Valley on the art. That would be my next stop. Otherwise you have t guess at the various sharpening angles.
      try searching the internet
      I found this:
      http://www.vintagesaws.com/library/primer/sharp.html
      which seems like a good starting point.
      • L. D. Jeffries
        • 747
        • Russell, NY, USA.
        I don't know bout the rest of the country but when I tried to have a hand saw sharpened at my local sharp'ng shop they said sorry too time consuming! So I went to the Amish, for the cost guess I should have bought an outfit and learned how to do myself. But then I only had two saws and how long will it be before they need sharp'g again?
        RuffSawn
        • williamr
          • Dec 2006
          • 56
          • BT3000SX
          DAGS...
          I found this:
          I found that site too., and I just had a look at the site -- indeed that is a good description. Been a while since I sharpened a hand saw -- but it all looks right.
          I knew LV had the set.
          http://www.leevalley.com/wood/page.a...=1,43072,43086
          • Jim Frye
            • 1364
            • Maumee, OH, USA.
            • Ryobi BT3000 & BT3100
            No local service!!!
            Wow, I am a bit shocked that the local shop would not do it. We have two shops in town that do saw sharpening and both are pretty reasonable in price. I haven't checked lately, but I know some professionals who still have hand saws sharpened on a regular basis. Both shops use machines to sharpen saws, like they do blades, so labor is not an issue.
            Jim Frye
            The Nut in the Cellar.
            • Tom Miller
              • 2507
              • Twin Cities, MN
              I've sharpened a grand total of one saw -- one of those "Gent's" dovetail saws. At $20 I didn't expect the saw to do well out of the box, and planned to sharpen it right away. It helped immensely -- as in, the saw shouldn't be used as is!
              Sharpening was fairly easy (it's a rip saw). But then I stoned too much of the set out of it, so it's a little too tight. Still, it was good enough to use on a couple dovetailed drawers on a recent project.
              I recently bought a saw set from Lee Valley to correct the set. But, since I also bought their new dovetail saw in the same order I may not work on the Gent's saw any time soon.
              Regards,
              • shoottx
                • May 2008
                • 1240
                • Plano, Texas
                All of these might help
                http://home.grics.net/~weir/Old_SAWS_Restored.html
                http://www.technoprimitives.com/
                http://www.medalliontools.com/Handsa...ngService.html
                Chris Schwartz also recommended this person in York, PA: Steve Cook (SharpeningGuy01@aol.com): 1160 Taxville Road, York, PA 17408
                Or you could do it yourself
                  Thanks Mike, I am also checking out some local sharpening services.
