What About This Lathe?
    LOML has seen one at HD and is considering it as an early birthday gift. Should I give her the go ahead? I could be turning by Friday.
    It is not a bad little unit. The belts are easier to access to change speeds than the Jet non-VS, but you're still gonna wish you had sucked it up and got a VS unit. The indexing feature on the Jet is also nice, whereas the Delta doesn't have one, but most turners won't need that feature.
    I cannot remember if the spindles on the Delta are Morse #1 or #2. If they are #1, you might consider a different unit, as Morse #2 tooling you may buy down the road most likely would be migratable if you upgrade to a bigger or more featured lathe, but #1 tooling will most likely not be compatible.
    I am also pretty sure that the model you show is discontinued. This may not really be a concern to you, though.
    • Alex Franke
      • Feb 2007
      • 2641
      • Chapel Hill, NC
      I have one, and I like it a lot. Mine's a #2.
      • herb fellows
        • New York City
        What is the model #?
        • Alex Franke
          • Feb 2007
          • 2641
          • Chapel Hill, NC
          Mine is the LA200 -- it looks like the same one to me. I got it a while back for $120 when Amazon was blowing them out.
          • TB Roye
            • 2969
            • Sacramento, CA, USA.
            I have one, I use to turn pens and some other small spindle type projects. It does have the #2 Morse taper. It is a good bigners Lathe..
              Thanks guys. I realize that Delta has discontinued this model but that doesn't really bother me( I bought one of the last BT3100's) . As long as I won't be finding myself longing for a better lathe with in the first year or so.
              • DUD
                • 3309
                • Jonesboro, Arkansas, USA.
                Richard
                I don't have this lathe but I do have one with a #2 morse taper and it work fine for Me
                and it gives You an in on little money to get Your skills up. Bill
