Yet Another Tool?
  • jackellis
    • 2638
    • Tahoe City, CA, USA.
    Yet Another Tool?
    I should stop looking on CL 'cause it's breaking the bank.
    Someone nearby is advertising an AMT shaper with a cast iron table for $250. I have two good routers and probably need a shaper like I need a hole in the head, but I'm pretty sure this is a screaming deal.
    Do any of you own a shaper and if so, does this make sense or should I leave it alone.
    Of course if I'm lucky, someone has already put dibs on it.
    You can spend a fortune on bits for a shaper. If this one doesn't come with a good assortment, then your "investment" has only begun at $250.
    • kirkroy
      • Feb 2007
      • 343
      • Brunswick, MD
      Craigslist and the bargain forum here are The Devil... However, I'm pretty sure they are keeping the economy afloat...
        You would probably be happier sticking with a router in a table. Shapers do offer a wide latitude of profiles, but some shapers have less power than some routers. Most profiling you'll need to do can be done with a router. If the floor space isn't a question, and you can afford the expense and maintenance of a shaper, it can be a beneficial machine to own.
        I would recommend getting a power feeder, as it makes it a safer and more productive machine. I used one for a very short period before I decided to get a power feeder. You can buy multiple bases and mount them on other tools. Then it's a matter of just moving it to different tools. They can also be mounted on table saws and jointers. Shapers are great for large profiles, and if doing great quantities can make quick results. They are usually used by cabinet and woodworking shops that produce frequent mouldings or profiles.
          • 22109
          Shaper is kind of a specialized machine. $250 is probably a good deal if you need one, but... do your really want one?
          • jackellis
            • 2638
            Gentlemen, as usual you've provided good advice.
            I don't need a shaper, I probably do not have the space for a shaper and I'm not sure I can afford one if I have to start buying cutters for it as well.
            I have two fine routers (and two crappy ones), a table to mount one of them in (BT accessory table), and a selection of bits, which should be enough for the moment.
            For anyone who lives in or near San Jose, here's the ad. Please byt this thing before I change my mind!
            http://sfbay.craigslist.org/pen/tls/1047716739.html
            • L. D. Jeffries
              • 747
              • Russell, NY, USA.
              Isn't the AMT outfit long gone out of business? Might be a problem getting parts or even shaper bits if they aren't standard sizes?
              RuffSawn
