Ryobi 18v Batteries
  • DUD
    • 3309
    • Jonesboro, Arkansas, USA.
    Ryobi 18v Batteries
    I went to HD yesterday to get a new battery as My others woul not charge up. When I
    got home, I put the new one on the charger. I got the manual that came with the new
    battery and started reading. I found out that if the yellow and green lights come on that
    it means that the battery is hot or seriously undercharged. It said to let the battery cool
    and insert into charger for 30 minutes or more, the red light might come on and then will
    charge. I did and 3 batteries charged up, the last one I forgot about it and this morning it
    had turned green too. Bill
  • jhart
    • 1715
    Always good to read the manual. Glad it solved your problem. Did not charging happen with all of your older batteries, or just the one?
    • DUD
      • 3309
      All of My battery's work now. Bill
        That's good to know, Bill. I don't think I have anything like that on mine, but now I'll have to check.
        • gjat
          • 686
          • Valrico (Tampa), Florida.
          Instead of leaving batteries 'on charge', I hook up a cheap timer, set it to turn off ine 4 or 5 hours, manually flip it on (without the 'on' tab), and forget it. Since I remove the 'on' tabs, it doesn't turn back on and I don't over-charge the batteries.
          • SawDog
            • Sep 2008
            • 37
            • Pennsylvania
            OK...*That's* a pretty cool idea! Gotta try that!
            Thanks!
            Hal
              As a point of safety, someone I know on another forum had a battery heat up and he never noticed it until he came in and found the charger base half melted. The timer is a great idea.
