Why 51/64 Router Bushing?
  • phrog
    • Jul 2005
    • 1796
    • Chattanooga, TN, USA.
    I just received a set of router bushings for Christmas. Included is both a 3/4 inch and 51/64 inch bushing. I'm not sure I understand why two bushings so close together in size are included. Can someone enlighten me on this? Thanks.
    Richard
    Richard
    Just guessing, but it would probably be used when creating a dado for 3/4" plywood.
      couldn't find a ref or what its used for, I'll hav to think about hat for a while. But lots of sets include that size, so its a common use.
      That's 3/64th over 3/4"
      I assume OD.
      • phrog
        • Jul 2005
        • 1796
        I'm not sure I understand the concept here. What difference would the 3/64 make?
        Thanks.
        Richard
        Richard
        • phrog
          • Jul 2005
          • 1796
          I assume OD.
          Yes, Loring, it's OD. I have also noticed that most sets include that size, so I thought someone on this site would surely have used it. Thanks.
          Richard
          Richard
          • herb fellows
            • New York City
            By any chance, does it come out to be a metric equivalent?
            • RAFlorida
              • 1179
              About 20.24 mm
              Or rounded up to 20 and a quarter mm.
                I made a fancy schmancy diagram to prove my point. It disproved my point.
                Go to the alternative theories from people who have a clue.
                  I found it.
                  Aparently popular hinge mortising kits work with standard 3.5" door hinges and 1/2" straight bits when used with the 51/64th OD, 5/8" ID router guide bushings.
                  Here's a couple, apparently there are more.
                  Milwaukee 49 54 0735 Hinge Butt Routing Template Guide Assembly
                  Precision-machined steel construction for accuracy and durability Universal, lock-nut design fits Milwaukee and most popular routers 5/8 in. inner diameter, 51/64 in. outer diameter, 9/16 in. barrel length Includes one lock-nut Limited warranty, Manufactu More
                  $6.75
                  from 1 store
                  Porter Cable Hinge Butt Routing Template Guide 42042
                  Hinge Butt Routing Template Guide Specifications Purpose Hinge Butt Routing ID 5/8 in OD 51/64 in Distance Pase Base 9/16 in-Tools/Power Tools/Routers/Accessories More
                  • phrog
                    • Jul 2005
                    • 1796
                    Thanks Loring. I had given up finding it myself. Makes sense.
                    Richard
                    Richard
