Impact drill/driver question
If you want to get hex shank drill bits, here's a few I like McFeeleys they have dedicated hex shank to fixed chucks so each bit will have its own holder, allows quick change while allowing the bits to be replaced (with the normal hex shank, break a bit you have to replace the whole thing.) but, at $4-5 each adapter it can get expensive.
http://www.mcfeelys.com/category.asp...0bit|939218521
http://www.amazon.com/b?ie=UTF8&node=552400
http://www.acehardware.com/sm-dewalt...i-1291282.html
just do a search on google for hex shank drill bitLast edited by LCHIEN; 01-05-2009, 11:56 AM.
There are other uses for the hex shanks then just to put them in an impact driver.OTOH...
I was using my B&D impact driver today and i noticed that the bag of bits that came with it include about 4-5 drill bits to 1/4" dia. mounted to hex shanks. The shanks even have the quick release/retaining groove. So apparently they think people want to drill with them...
The problem I have when drilling with the impact driver is it has horrrrrrible runout compared to a normal drill. It's also louder then sin. And kinda hurts my hands.
I only use mine for drilling when I'm feeling particularly lazy - and then only to drill studs for electrical wire.-John
-Henry BlakeComment
I will definitely agree with that- drilling with an impact driver is for convenience, not accuracy.There are other uses for the hex shanks then just to put them in an impact driver.
I only use mine for drilling when I'm feeling particularly lazy - and then only to drill studs for electrical wire.Comment
LCHIEN
