Router dimensions
  • rjwaldren
    • 368
    • Fresno, CA
    Router dimensions
    I'm sketching out a new router cabinet and would like to get some input on the size of the router chamber. (Trying to maximize storage) Right now it will have a Hitachi 2 1/4HP so it's fairly small. I'm sure that there will be plenty of room side2side and front2back - but how tall should I go to ensure that I can eventually move to a 3-1/4hp plunge model? It will be on a plate so removal out the front won't be an issue.
    I've looked for outside measurements of the M12v and M12v2 and found only base measurements.
  • RayintheUK
    • 1792
    According to Amazon:
    • Product Dimensions: 11 x 9 x 12 inches ; 12.2 pounds
    • Shipping Weight: 21.2 pounds
    HTH
    Ray.
    Did I offend you? Click here.
      I checked Hitachi's site and the height wasn't listed that I could find. Maybe a member here might have one that could respond to your post. If not it might be worthwhile to grab your tape measure and go to a store that sells them and measure one to be sure.
        I suggest you not design tightly around a specific model. You might change your mind, the manufacturer could discontinue or revise the model you're looking at, another manufacturer might come out with something you like better, etc.
        That said, I've been going through a similar exercise in designing a new routing station that will not only serve as a router table but also store all my handheld routers, bits, and accessories. For my Porter-Cable 7518 (about as physically big a router as you'll find) in a lift, I settled on 14" from the top of the table to the bottom of the box. With a 3/4" allowance each for the box bottom and top, that nets out to 12.5" clear inside the box.
        For my various handheld routers, fixed and plunged, of various brands, I determined that a 12" net high shelf space was adequate. This allows the routers to be stored without depressing the plungers, and without putting any excessive bends on the cords. Note that this dimension is within 1/2" of what I figured for the router/lift box, above.
          I would suggest if you have the M12VC, or KM12VC, that you measure the base you want to use, AND the entire height of the motor assembly, add them together, and then add another 2" for good measure and you should have your depth... Getting the motor in and out of my router table is a PITA because I am too snug...
          • rjwaldren
            • 368
            • Fresno, CA
            Thanks Ray, Amazon (doh!)
            Actually the measurements you guys are suggesting are tighter than I was guessing, they get to be behemoths with the adjusters jutting out, but I was way over estimating, so the 15" I was hoping to eek out should be great.
            • MikeMcCoy
              • Nov 2004
              • 790
              • Moncks Corner, SC, USA.
              • Delta Contractor Saw
              Mine allows a little over 16" and although I haven't measured, there is more than enough room under my biggest router which is the Freud FT3000. That one is about as tall as they get.
