I bought one for a specific task on my boat where nothing else was going to do the job easily. It worked well cutting 3/4 plywood if you took your time. I don't use it since the day the switch went bad in it and I had it sitting on the floor switched off while I plugged it in. It took off spinning, clipped my sneaker, I jumped, it jumped, I don't know what it must have looked like but LOML was calling me Tim the Toolman for the rest of the day.
Is the Rotozip worth buying?
is the Rotozip worth buying?
Yes, I think that it is...especially for the price you quoted. It is a well made tool for what it was originally designed for....cutting holes in sheetrock and
the like. I have used mine as smaller handheld router, and with the proper bit it does a good cutting job. I have one in my truck to use at work when I need to work on lock strikeplates or other tasks. The Sears all-in one version
is also a good one if you are doing small case hinges and small half mortise
locksets in jewelry boxes and other small projects as well. eezlockComment
For $35 I would do it... also I see them listed on Amazon as refurbs for like $45 I believe with the bag and a few bits. I like mine but I would agree... I don't use it much but bought the extension with the pin grip and use that with my cutoff bits I have for the dremel.Comment
I have a flex-shaft for mine that is nice for using all kinds of Dremel 1/8" points for getting into tight curves and corners.Comment
I would check out the FTC.gov site, as there were several models recalled. I bought one from a friend (busted collet lock) and went to find out how much parts were, and found mine was covered by the recall (dealing with the collet lock or the handle). I gave $10 for it, and they said pull off all the parts (spare collets, adapters, handle etc. They shipped me a refurb and had me RMA the old one in the box.
I payed more for the router base attachment, at a junk store ($20). I've used it as a trim router, and have both a brother and brother in law with basement remodel/drywall jobs in the future, (already done one friends), so it has paid for itself. I am seriously tempted to garage sale it, after those two jobs (not doing anymore), and get my $$ back out of it.She couldn't tell the difference between the escape pod, and the bathroom. We had to go back for her.........................Twice.Comment
If you are doing remodeling, you may find it useful. I tried my dremel when I had to cut existing floor tile with no luck. I ended up using a rotozip with the small diamond blade with the saw attachment. The Fein tool won't do tile, else I would have bought is instead. For a woodshop, however, there are better solutions.
KarlComment
