cheap bearing guides for HF bandsaw
  • eddy merckx
    • 359
    • Western WA
    • Shop Fox Cabinet
    Someone mentioned that the cheap (affordable) bearing guides for the HF 14" bandsaw are no longer available. I noticed these on ebay. They look identical.
    roller guides
    I have the ones sold at HF. They work great for me.
    Eddy
    • 9554
    That was me...
    I ended up with Accura Micro Adjustable roller bearing guides. VERY nice upgrade, but cost quite a bit more than these. I sure wish HF would sell some good micro adjustables for their saw...
    • eddy merckx
      • 359
      • Western WA
      • Shop Fox Cabinet
      Me too. Since they seem to sell as many riser blocks as they can import, it seems logical to offer decent blade guides too.
      Eddy
      • jhgrady
        • 297
        • Alexandria, Va, USA.
        Got them for my 14" HF
        Thanks Eddy
        John
        • cwithboat
          • Jan 2008
          • 614
          • 47deg54.3'N 122deg34.7'W
          • Craftsman Pro 21829
          John,
          Let us know how they work out.
          regards,
          Charlie
          Rudyard Kipling
            • 9554
            Eddy
            I added the HF riser block kit to my 32208, so I am responsible for at least one. Since I bought my saw, I have seen 3 32208s on Craigslist (each in a different condition) with the riser block kits. A common setup for these saws seems to be.
            #1. Those roller bearing guides you listed, or at least the HF versions of them.
            #2. The Riser Block kit. There appears to have been a while when Harbor Freight messed up and dropped the riser block kit, so there are a few of them with the Grizzly riser block kit installed. (Grizzly H7316 I believe).
            #3. I have seen a few folks with the HF 98201 Prescision Rip Fence. I plan on adding one with a shop built tall fence later for resawing.
            #4. Wheel brush. I have seen a few where it looks like they riveted an old toothbrush head to brush debris off of the lower wheel.
            #5. Improved dust collection. I have seen some where the lower wheel guard has a DC port cut into it...
            #6. That Grizzly Blade Tension Release lever mod. Several owners have added the blade tension release assembly from the Grizzly GO555 to the Harbor Freight Band saw. Not a bad deal.
            #7. Timberwolf blades.
            • eddy merckx
              • 359
              • Western WA
              • Shop Fox Cabinet
              Those are good upgrades for sure. I added the lower 4" DC port `on mine. It did makes a huge difference--the bandsaw no longer spews clouds of fine dust while resawing. I use a combo of the DC pulling from the lower door and a shop vac pulling from the stock lower guide port. I still get big crumbs all over the table but at least I can breathe.
              I did two other things on mine that really help; I installed a 1.5 hp motor and hinges on the doors.
              The motor is really easy to do. I got a used one for pretty cheap. It makes a huge difference for resawing. The original 1 hp motor (HF speak for 1/2 hp) made resawing difficult. My old motor would get so hot that it would shut off. The 1.5 hp motor will pretty much cut whatever you can stuff into the saw. I recently resawed 10" x 8' slabs of madrone without trouble.
              The other thing which used to drive me nuts was having to remove the doors every time I wanted to look inside the saw. I eventually sawed off the left knob and installed hinges. I just drilled holes in the doors and sheet metal wheel shrouds. I used 2" hinges held on with 10-24 screws and nuts. It works much better. The right knob stays in order to keep the doors from rattling. I noticed that Grizzly uses a similar system. They must have snuck into my garage.
              Eddy
                • 9554
                I haven't had any real power problems with my stock HF motor. But more power is always better. I guess I must be channeling Tim Allen or something... I have considered tossing a 1.5HP universal motor at it. I happen to have one up in the attic that I believe just needs brushes... The mounting and main shaft arragement are identical. I should be able to install the brushes and mount it up. I figured that was a someday project though. The OE motor does work well enough for now... Been sawing plenty of white oak with it no problem.... I just keep my feed rate down.
                • jhgrady
                  • 297
                  I ordered these on Saturday and they arrived on Monday!! They do fit my HF 14" Band Saw. I'm pleased so far.
                  John
