So this is a new to me kind of thing, but the post, and base plate on the new to me Northern Industrial Drill Press both have some surface rust on them. I would like to get rid of the rust and seal them. I figure I can wet sand the base plate with some emery cloth and WD-40 on a sanding block. But I want to paint it afterwards. What do I do to get the oils and junk completely off? And how do I deal with the post?
Cleaning off the rust on my DP.
Please like and subscribe to my YouTube channel. Please check out and subscribe to my Workshop Blog.Tags: None -
Mineral spirits or kerosene should be able to clean off most anything that's on there. I wonder though how your paint job will hold up on the column with all the raising and lowering of the the table that is done with a drill press?_________________________
"Have a Great Day, unless you've made other plans" -
No paint on the column, just the base plate...
Not sure what to do to keep rust from forming on the column again, but I figure paint on the baseplate (and repaint on the belt cover) should keep the oxide from creeping back in...
I have a quart of mineral spirits in the shop...
I guess I should clean it up with the mineral spirits, and then what? Will the mineral spirits leave a residue or can I apply a finish to the baseplate after that?Please like and subscribe to my YouTube channel. Please check out and subscribe to my Workshop Blog.Comment
Mineral spirits with coarse steel wool and a wire brush. the wipe it down with clean mineral spirits and you are ready to paint.Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas EdisonComment
I hate using WD-40 around tools that I might be drilling wood on. I cleaned my drill press last week using naval jelly and a green scrubbie. I then cleaned it with windex (to cut all the oils) and sprayed it with clear spray paint. This weekend I'll put another coat of clear on the tables and some machine oil on the shaft.
Naval Jelly? Isn't that a bit strong? I understand the Windex part. Rubbing Alcohol is great too as it evaporates and doesn't leave a residue.I hate using WD-40 around tools that I might be drilling wood on. I cleaned my drill press last week using naval jelly and a green scrubbie. I then cleaned it with windex (to cut all the oils) and sprayed it with clear spray paint. This weekend I'll put another coat of clear on the tables and some machine oil on the shaft.
Why would the WD-40 matter if it was cleaned up properly afterwards? Just curious... I like to know folks thoughts on these things...Please like and subscribe to my YouTube channel. Please check out and subscribe to my Workshop Blog.Comment
Naval jelly isn't strong, and it doesn't take off paint. I just grew up using it I guess. WD-40 is okay if you clean it all off, but over-spray can be an unintentional mess (DAHIK).Naval Jelly? Isn't that a bit strong? I understand the Windex part. Rubbing Alcohol is great too as it evaporates and doesn't leave a residue.
After you get the column nice and shiny, you can apply one of the commercial rust inhibitors. I use the Boeshield T-9 aerosol spray.LarryComment
Well, it all appears to be simply surface rust, however, I am finding some areas where the oxide buildup is substantially heavier. I have attempted the scrubbing approach with limited results. I have turned to taking a paper towel soaked in mineral spirits, and soaking the areas with mineral spirits, and reapplying, then scrubbing with the steel wool...
I have a feeling this is going to take a while... If I were charing by the hour this would be one expensive drill press!Please like and subscribe to my YouTube channel. Please check out and subscribe to my Workshop Blog.Comment
I bought a rusty Jet 6" Jointer a couple of years ago. First I used a wire wheel on a drill to get the major rust off. Then I followed up with a random orbital sander and some 220 grit. A coat of paste wax and it was as good as new.Rand
"If all you have is a hammer, everything looks like your thumb."Comment
Naval Jelly would have dissolved it all in minutes if you just slather it on. It's not harsh, I've never used gloves with it. I've used it to take off serious rust on car parts, albeit I used 2 applications, letting it soak and scrubbing it off.
Thanks for the idea of boeshield. I've got blad lube that I'm going to use next time.
I think I am going to have to use Naval Jelly. I have gotten as far as I can with mineral spirits and steel wool... I have spots that still need to come clean and shiny...
AS soon as the spots are off, I was planning on hitting this thing up with a good paint job on the base plate, as well as the belt cover, the column and gear were going to get rubbed down with marine trailer bearing grease to protect and lubricate it.Please like and subscribe to my YouTube channel. Please check out and subscribe to my Workshop Blog.Comment
I think you may have a problem with that bearing grease acting like a magnet for all that dust and chips from drilling.Comment
Any suggestions for protecting and lubricating? I know protecting is easy enough. Lubricating is where it gets difficult...Please like and subscribe to my YouTube channel. Please check out and subscribe to my Workshop Blog.Comment
