HF BS assembly
  • jarhead
    • 695
    • Boynton Beach, FL.
    HF BS assembly
    I hate to start another HF bandsaw assembly thread, but could not find the information I was looking for. I am assembling the stand and really got confused by the instructions. Are they correct in guiding the stand assembly? I am not sure if the motor plate bracket (9A) is towards the front or the back of the stand. On page 7, in figure D, it is shown towards the front, whereas in figure E, towards the back.
    Here's how I have assembled it so far:
  • mehranh
    • 292
    • San Francisco, CA, USA.
    I am not in front of my band saw...but the picture looks correct. The motor will be hanging from underneath the mounting plate, and the pully will be facing the opening on top of the stand. So I think you're up to a good start.
    • markmt
      • 69
      • kathleen, georgia, USA.
      Sir, this looks right,before you go further,do a search under HF BANDSAW,JR,wrote some instructions. I believe you will need a plate to support the motor. I used a 0.050 AL plate across the bottom. The motor is heavy. You will also have to slot the bottom holes for fitting the motor. First look up all the threads. Believe me you will save some time.
      Mark Taylor
      • jarhead
        • 695
        http://www.bt3central.com/forum/topi...&TOPIC_ID=9207
        JR's picture looks different than mine - his picture was taken from the back of the stand (based on the power switch being on the right), but mine was snapped from the front. Both of our motor plate brackets are slanting in the same direction though.
        Something like Grizzly's BS does? Not sure if I have any metal working skills to make something like that.
          Jarhead, that's the main point of my referenced posting. Figure D is right, and Figure E is WAY wrong. Using my instructions with my version of Figure E, you'll find 9A at the front. The motor mount assembly 10a sloping down from the front to the rear.
          The aluminum plate idea is that you add something to 10A with four holes to help keep the motor aligned when you are mounting it or changing the belt. Once you mount the motor you'll get it.
          good Luck,
          • jarhead
            • 695
            I understand what you're saying - that means I didn't assemble my stand correctly. Figure D is showing 9A (Z) bracket at the front of the stand and I have it in the back as shown in this picture:
            [EDIT]
            OK, I can't be this thick-headed. If 9A is at the front of the stand please look at this picture (taken from the back) and tell me if your stand has the round holes in the 9A which will only line up with the back of the saw. You can even see the slots on the top of the stand have them drilled out. The way the round holes are drilled, something tell me that someone drilled them and then returned the BS.
            [/EDIT]
            • markmt
              • 69
              Jarhead,those holes looked drilled.
              mt
              • jarhead
                • 695
                Exactly - you can even see bare metal on the inside of the holes. As I said, my feeling is that someone bought the BS, drilled the holes with bracket 9A screwed in the back, and then returned it. Grrr! I hate buying anything that was returned.
                Mark,
                After looking over the pictures posted by JR and Figure D in the manual, my picture at the top of the thread is incorrect. In that picture, 9A "Z" bracket is mounted in the back of the stand making the motor plate 10A point in the wrong direction.
                Do you have a picture of the aluminum plate that you made? I am not sure what you mean by having to slot the bottom holes to fit the motor. To fit the motor to the fabricated support plate?
                • germdoc
                  • 3567
                  • Omaha, NE
                  • BT3000--the gray ghost
                  These pictures are startingly reminiscent of the jointer stand and motor assembly. Whatever Shanghai engineering school dropout designed these stands, they are unusual and unique. The instructions, of course, are mere vague hints, not really concrete steps to follow. And poorly translated from the Mandarin.
                  The funny thing is that if you muddle through it will work and is surprisingly sturdy.
                  Jeff
                  • Hal4son
                    • 132
                    • Richardson, Texas, USA.
                    Reassuring to find out that I wasn't the only one confused by the HF instructions. Took me approx. 4 hrs just to assemble the base, put it together, think, take it apart, put it back together, think again, take it apart, rethink the whole mess, put it back together. Finally got it right - it works anyway, and is far more sturdy than I would have initially thought. But sorry, I can't remember exactly how I did it...but you're right, one of the pictures/figures is exactly backwards from the other one. Boy, am I glad that's behind me.
                    2nd Amendment - without it, the others are just words written in the wind.
                    • Lonnie in Orlando
                      • 649
                      • Orlando, FL, USA.
                      Jarhead:
                      HF doesn't waste time and money correcting errors!! Here's a post from 2001 that I used to help assemble my HF BS ...
                      http://groups.google.com/groups?q=HF...usc.edu&rnum=3
                      And yes, the motor mount slopes from upper right down to lower left when standing at the infeed side of the saw.
                      - Lonnie
                      • jarhead
                        • 695
                        quote:Originally posted by Lonnie in Orlando
                        Jarhead:
                        Lonnie,
                        Thanks for the link. If the motor mount slopes the way you decribe it (and as JR had posted in his assembly thread), then my picture on the top is incorrect. Again, what threw me completely of course, was the round holes that someone drilled before returning the saw.
                        • markmt
                          • 69
                          Jarhead, I do not have one of the snappy digital cameras,still living in the stone age i guess, but let me explain it to you.
                          1) Your motor on the bottom will sit free floating on the motor bracket,this thing is heavy. I made a plate of 0.050 Al plate that sits across th bottom to support the motor. You can use a flat strip as long as it supports the motor. Whatever method you use,make sure it is bolted in.
                          2) I had to slot the motor bracket and stand. This was necessary to get the motor on the bottom to line up properly with the motor on top. You slot left to right. I used one of those metal cutting drill bits from HF for 6-7 dollars per 3 pack.
                          To sum up,the bracket/plate will keep the motor from vibrating and make belt adjustment easier. You must bolt it in for safety sake. Slotting the holes may not be needed if your bottom motor lines up good with your top motor. I suggest you put everything together loosely and check it.
                          Mark Taylor
                          • jarhead
                            • 695
                            Well, it's confirmed, the saw which I bought was used and returned. Besides the fact that someone drilled additional holes (pictured on top), when I pulled out the saw body, it had sawdust all over it. Here's the problem, I had my uncle by the saw for me from PA and drive it to NY. Exchanging it will be a bit of a problem. I think I will call the store and ask them to ship me a new saw and have this one shipped back at their own expense. Another option is ask for a discount. Otherwise, I will ask my uncle to put a stop payment on the credit card.
                            [edit]
                            Just spoke to the manager of the store and explained the situation. The only thing she could offer is 10% discount on the next store purchase . I explained that I am not going to drive 200 miles to her store to save 10%. Tomorrow I will be calling customer service to see what they can do. Otherwise, I will be calling the credit card to file a dispute.
                            [/edit]
                            • markmt
                              • 69
                              Jarhead: 10% off your next purchase is a slap in the face,you can get the 10% coupon off this site. Essentially they sold you a used piece of eqpt. as new. I am by no means an attorney. First take a deep breath and bypass the store manager. Go to customer service. Have a plan in hand,if you let them make the decision for you they will. I would go for the new one with shipping at their expense. Just remember " You Catch More Flies With Honey, Than You Do with Vinegar".
                              good luck
                              mark taylor
