I honestly think a biscuit cutter is an excellent example of a tool you don't need. I bought one several years ago b/c I thought I was supposed to use biscuits to reinforce joints. The longer I did wwing, the more I realized that most glued joints don't usually need them, and I used the biscuit cutter less and less.....you may have noticed that Norm has also gotten away from using them, and there's a good reason. Most well prepped joints just don't require them, and for the few joints that do benefit, a router bit will do the trick for ~ $10. I'm far more likely to use pocket holes than biscuits....I sold a very good DeWalt DW682K last year and have not missed it. A jointer will do more for your joint strength than a biscuit cutter if you don't already have one....flat, straight hardwood stock for every project is a beautiful thing!
I'd save your money and get a basic $20 pocket hole jig, router bit, and some wood, or definitely consider adding a jointer to your arsenal if you don't aleady have one.
That's my story and I'm sticking with it!
