Cordless Drill Sparking
    My 18V cordless drill sparks when the motor stops. I am embarassed that I don't know if this is normal or not. I haven't ever noticed it before but then I am rarely in a position where I can look into the vents on the side of the case when the motor is running. So is this normal? The drill works fine otherwise.
    I hope it's normal. Mine does it too (I have a Ryobi).
    • SHADOWFOX
      • 1232
      • IL, USA.
      • DELTA 36-675
      I have a Ridgid 18V hammer drill and impact driver and it does the same thing. My Makita LXT hammer drill and impact nor Bosch Lithium Ion drill or impact driver however doesn't. I think it's normal because both the Ridgid hammer drill and impact driver works fine and have not had problems with them.
      I know, I have an obsession with collecting cordless hammer drills and impact drivers.
      kind regards,
      Chris
      • Stan
        • 966
        • Kalispell, MT, USA.
        • BT3100, Delta 36-717
        Checked mine here. All give a spark to one degree or another.
        http://www.elksigndesigns.com
        • Wood_workur
          • 1914
          • Ohio
          • Ryobi bt3100-1
          my 12v makia does the same thing as well. I think its the brake or something.
          Alex
          • Tom Slick
            • 2913
            • Paso Robles, Calif, USA.
            • sears BT3 clone
            completely normal
              probably normal - it has a universal motor with brushes, that make electrical contact with the moving armature. That contact makes sparks. Most often you don't notice, some times you use the drill in a dimly lit area and you see them and it startles you.
              • eccentrictinkerer
                • Aug 2007
                • 669
                • Minneapolis, MN
                • BT-3000, 21829
                Here's an educated guess. Your 18 volt uses a permanent magnet motor. When power is removed the inertia of the armature and gear train turn the motor into a generator.
                One way to slow/stop the drill is to either short the motor or put a very low value resistor across the motor.
                The voltage being driven into the short causes the sparks for a revolution or two.
                Just my two ohms worth.
                • Hellrazor
                  • 2091
                  • Abyss, PA
                  • Ridgid R4512
                  David,
                  Your drill is faulty, send it to me and buy a new one!
