Marking tools?
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    Marking tools?
    What tools do you use for marking/layout?
    As a follow-up:
    Do you prefer hard (HB) or soft (4B) lead?
    Do you prefer fat or skinny lead?
    are you particular or do you use whatever is laying around?
    I prefer mechanical pencil, actually a drafting lead holder, with fat soft lead.
    182
    Wood Pencil
    33.52%
    61
    Mechanical Pencil
    32.97%
    60
    Ball Point Pen
    1.65%
    3
    Marker or Sharpie
    6.59%
    12
    Graphite stick
    0.55%
    1
    Marking Knife
    18.68%
    34
    Blood
    3.30%
    6
    laser
    2.75%
    5
    I quit using lead holders when my dogs ate my last good one. Finding the pointer was always a challenge too.
    I use some cheap mechanical .5mm now with a medium weight lead. They've got a side feed mechanism which helps them from rolling and a retractable point. Pack of 5 at CVS was cheap.
    I use the points of my dial claipers to score a line a lot of the time.
      • 22085
      i usually use a .5mm mech pencil.
      second choice, esp if the pencil mark is not visible (due to dark wood, texture) - sometimes a scratch awl which was not listed.
      Also frequently use the marking gauge, the one with a rod marked in inches and attached to a scribe wheel and a sliding edge guide.
        I mostly use regular #2 wooden pencils. The yellow ones, usually, but sometimes green or whatever else falls to hand. I dislike mechanical pencils because they're not sharp enough. For really precise work, I use an X-Acto knife with a standard #11 blade.
        Another medium I use is ordinary white chalk, the kind you used in grade school. Not for precise cut-it-here purposes, obviously, but for keeping track of what part goes where, which is left and right or front and back, etc.
        • shoottx
          • May 2008
          • 1240
          • Plano, Texas
          I mostly use regular #2 wooden pencils, the free ones generally. Carpenters pencils for rough work. I even have a mechanical sharpener, which I use if I forget my pocket knife
          I find the mechanical pencils always fail at the most in opportune times, usually late at night, out working on a project, or when there are no other good marking instruments available.
          I have also picked up a package of metallic silver sharpies for work on dark color wood.
          • BobSch
            • 4385
            I normally use a .5mm mechanical pencil. I like Larry's idea of chalk for marking pieces. Have to try that out.
            Bob
              For dark stuff (black laminate shelves) I have a couple of white bowling pencils that that many of the dart pubs use on their scoreboards around here. They're really just a #2 grease pencil. They get pretty soft in the Texas heat though. It's a lot easier with them than to try to locate the 'just right' reflection off a graphite mark.
                I usually use a mechanical pencil, sometimes a marking knife, sometimes a gauge. I also selected blood, as I have had it happen where I knocked a knuckle or something and found blood on my nice projects, hard to sand out, darn it!
                • Wood_workur
                  • 1914
                  • Ohio
                  • Ryobi bt3100-1
                  real pencil, prefer the feeling. I have a really nice sharpener so the line is always crisp. more so that I usually can with a mechanical pencil, however I do have some 4H (hard) and 4B (soft) lead I could use if I wanted to.
                  Alex
                  • Mr__Bill
                    • 2096
                    • Tacoma, WA
                    Well, I mostly use a pencil -- usually one with someones advertising on it. I do have some left of the 10 gross of #2 that i bought some years ago but the erasers are hard. I also checked blood... that usually is for marking the face of the board, and marking knife it really just a Buck knife or, more often a nail.
                    I have been thinking.. what i really want is one of those laser levels that after you get it just where you want it there is a button labeled... MARK and you press it and bzzap it's marked! When bored it could be used for killing flies.
                      For construction type work I use a flat sided carpenter's pencil. A .5mm mechanical pencil is favored in wood working and a sharpie for marking metal work.
                        Pappy and I are of similar tastes... A carpenter's pencil is OK for rough work, but the point can have too much "slop" for work requiring a degree of precision, so I use a 0.5mm mechanical pencil for that. Work on metals or plastics gets a Sharpie (XF point).
                        • Warren
                          • 441
                          • Anchorage, Ak
                          Usually a scribe. Rough cutting, anything laying at hand.
                          • messmaker
                            • 1495
                            • RICHMOND, KY, USA.
                            • Ridgid 2424
                            I use a pencil for the first mark then either forget where I laid it or I knock it to the floor where it falls and breaks the lead. I then go to the jar I keep pencils in, only to find out that it is empty or full of pencils with broken leads. It is a vicious circle.
                            • BobSch
                              • 4385
                              Mount a pencil sharpener next to the jar.
                              Bob
