The Little HVLP Sprayer That Could
    • 21978
    Originally posted by just started
    I would expect them to replace the hose for free! I have had the same hose on my compressor for over 30 years and it's still going strong.
    its not the same kind of thickwall hose as most compressors would use with tools.
    Its an integral hose, PVC, probably thin wall, lightweight for maneuverabiliity and low pressure and larger diameter for high volume.
    • jhart
      • 1715
      Got a reply from Rockler and they said their unit comes with a
      0.9mm tip and a 1.8mm tip. Will have to check mine as I think the only one I got with the unit was the one attached to the gun.
      • messmaker
        • 1495
        • RICHMOND, KY, USA.
        • Ridgid 2424
        [QUOTE=jhart;364222]The HF model/manual is sure a lot more detailed
        That may be the only time in history you see this statement.
        • jhart
          • 1715
          Messmaker you're right, you may never hear that again. But in this case, they go into detail about changing the various tips and Rockler has nothing. Outside of that, the instruction sheets are almost identical, except for the names of the companies on each.
          After checking, the 2nd tip is included in the box. I had seen it when unpacking the unit, but since the instructions didn't say anything about the different tips, I guess I had assumed that it was a replacement or something.
          • jnesmith
            • 892
            • Tallahassee, FL, USA.
            Originally posted by ragswl4
            I have had the HF HVLP Sprayer System for a little over a year and have used it for spraying cabinet doors with waterbase lacquer and it has worked well.
            What WB lacquer do you use with this system? I have the same unit and have been considering giving WB lacquer a try.
            Thanks.
            John
              I cannot say how it would work with the HF system but I get good results with Resisthane in my Wagner conversion gun. My guess is it would work well in the HF. Resisthane dries in an hour, is inexpensive (less than $30/gallon delivered), and is durable.
              • AlanWS
                • 257
                • Shorewood, WI.
                Hydrocote resisthane is exactly what I've sprayed from my HF sprayer. It works well. Highland Hardware sells it, and I'm not aware of anyone else who does. I'd like it if a local store carried it. Actually, I'd love it if Highland opened a store in my state.
                Alan
                  You can also order Resisthane from Hood finishing, that is usually how I get it. I never have luck ordering on-line so I call them.
                  • phoneman697
                    • Apr 2003
                    • 38
                    • Columbus, OH, USA.
                    #24
                    Has anybody shot waterbased enamels through any of these units? How did it turn out?
