Router Saw?
  • dkerfoot
    • 1094
    • Holland, Michigan
    Router Saw?
    So, is this just a radial arm saw that someone has badly mangled the name of, or is it something else?
    http://grandrapids.craigslist.org/tls/751421393.html
    Doug Kerfoot
    KeyLlama.com
  • jonmulzer
    • Dec 2007
    • 946
    • Indianapolis, IN
    Mangled name, though I do remember seeing a radial arm saw that had a router attachment. I am not sure who made it, or how reliable it would be, but it looked like it would be handy for some cases.
    I need to find an older radial arm saw, they just seem like they would be handy if I could carve out the space in my already cramped shop.
    • Tom Slick
      • 2913
      • Paso Robles, Calif, USA.
      • sears BT3 clone
      My dad had a radial arm saw that you turned the motor sideways and it had a collet for router bits. I think it was a Wards.
      • Daryl
        • 831
        You can see the threaded shaft on the left of that saw. Just screw on a collet. It will run too slow to do fine work tho.
          You could rotate the motor on my old Ryobi RA200 and use it as a router. It seems to me that the router collet shaft turned 10,000 rpm, I never used it as a router so no idea how well it worked.
          • eezlock
            • 997
            • Charlotte,N.C.
            router saw?
            Hardly a router saw, I've seen a few of them for sale around here. It still looks like a radial arm saw to me! I was never a fan of those saws years ago,
            have used them a few times, still prefer a good tablesaw to them any day.
            eezlock
            • just started
              • Mar 2008
              • 642
              • suburban Philly
              Sears parts site says that model # is a 9" RAS.
              • docrowan
                • Mar 2007
                • 893
                • New Albany, MS
                Radial Arm Saw Uses?
                I know a number of members here have radial arm saws, but for someone who does not already have one, but does have a CMS and a tablesaw, is there any advantage to owning one? I read that they had some trouble in maintaining accuracy and the new ones are always priced a good bit higher than a SCMS of almost the same capacity.
                - Chris.
                • Tamarack
                  • Oct 2003
                  • 199
                  • Speedwell, TN USA
                  I don't think you can dado a shelf side with a SCMS.
                  Paul
                  • dkerfoot
                    • 1094
                    • Holland, Michigan
                    I have had the chance to get good deals on RAS, but my impression is that when people have a tablesaw, router table, SCMS and a RAS, the RAS usually doesn't see much use and it is pretty rare for it to be the only tool that can do the job.
                    Given my space constraints, I have decided to pass on them, even when they have been stupid cheap.
                    Doug Kerfoot
                    KeyLlama.com
                    • rjwaldren
                      • 368
                      • Fresno, CA
                      In addition to overhand dado's and ripping when turned parallel fence, I've seen them used for end boring. Never thought about routing, and can't say I see much use for it.
                      BTW - Whaler, I was shopping CL recently and found a RA200 for $20. When I googled for info all I found was recall notices. Apparently there is enough of a history of breaking mounts resulting in dropping saw heads during use that Ryobi recalled them all. It just reaffirmed to me that I don't want a RAS around. It's definitely the tool I fear most, and not in the good respectful way - More of a "I'm about to lose a limb regardless of the precautions I take" way.
                        • 22085
                        Originally posted by rjwaldren
                        ... Apparently there is enough of a history of breaking mounts resulting in dropping saw heads during use that Ryobi recalled them all. ...
                        that makes it an such an exciting tool to use.
                        • KLF
                          • 98
                          • Barrington NH
                          • BT3000 (of course)
                          My RAS was one of my first tools that I bought after getting married, way back in 1984. I used the heck out of that thing, my workbench was my first project. But, now that I had a SCMS and a BT3000, I never used it anymore. I bet it sat for 2 years without being turned on. So, I sold it 2 weeks ago, got $150 for it.
                          They are very dangerous tools, especially when ripping. I've had mine throw lumber across the shop and splinter more than one piece of wood. I'm surprised I never got cut with it, but I always tried to use a fingerboard.
