Drill opinions.
  • buck23
    Handtools only
    • May 2008
    • 3
    • So. Cal.
    Drill opinions.
    I'm trying to choose between two cordless drills. Either a Craftsman 19.2V or Hitachi 14.4V. I got both as gifts & only need one. The Craftsman has more torque and higher voltage but I think the batteries are Ni-Cad. The Hitachi is lighter & Li-Ion. I'm leaning toward the Craftsman but thought I'd see what you guys think.
    Craftsman C3:http://www.sears.com/shc/s/p_10153_12605_00911548000P
    Hitachi DS14DFL 14.4 Volt Li-Ion: http://www.amazon.com/Hitachi-DS14DF...0521436&sr=1-1
    Thanks for any opinions and suggestions.
    If I was to buy everything again new I would tend toward Lithium batteries. However if the craftsman you have also has the right angle drill I would keep that one as there are times when it will really come in handy.
      the Li-Ion battery system is more expensive but much better battery system than NiCad in almost all respects except cost. Lighter, smaller, more charge cycles, better lifetime, more capacity etc.
      Given a choice with cost not factored in, the Li-Ion drill would probably be my choice unless you are enamored of the big "SYSTEM" of interchangeable Craftsman tools you can get.
      • Knottscott
        • 3815
        • Rochester, NY.
        • 2008 Shop Fox W1677
        I think I'd keep the Hitachi for the Li-Ion battery. The Cman 19.2v is a pretty big drill and has Ni-CAD batteries. It's powerful enough but is a handful for marathon sessions and delicate work. On the other hand, there are a bunch of handy accessories for that C3 platform, including a Li-Ion battery pack/charger.
        • buck23
          Handtools only
          • May 2008
          • 3
          • So. Cal.
          The Craftsman has more torque but I have the same reservations about Ni-cads mentioned. Although, I have a Ni-cad drill I bought at HF for ~$30 years ago that still works but, the battery capacity is dropping. Either one will be an improvement.
          • Tom Slick
            • 2913
            • Paso Robles, Calif, USA.
            • sears BT3 clone
            Whatever you buy make sure it has a 1/2" chuck, at some point you'll get frustrated if it doesn't.
            this is just my opinion but once you step up past needing a 14.4v tool you should use a corded tool. the bulk and heft of a 18v and beyond Nicad or Nimh drill has no advantage over a corded unit except when you are working somewhere where "plugging in" is not practical. a $75 corded drill has significantly more power then a $150 cordless drill and it's power supply will never wear out and need expensive replacement.
            with Lithium batteries it is a different story. the size and weight is reduced so I see them as practical as a 14.4v.
            my point is; get a 14.4v. getting a bigger cordless drill of marginal benefit.
            • Handy Al
              • 416
              • Worthington, OH, USA.
              I bought the Craftsman a couple of months ago to finish a project after my Ridgid 18V died and I didn't have time to deal with the warranty. I went with the Craftsman because of previsous experience, the assortment of "add-ons", and the fact you can upgrade to the lithium battery.
              "I'm growing older but not up." Jimmy Buffett
              • goslin23
                • Feb 2007
                • 233
                • Richmond, TX
                • Rigid TS3650
                I have the Craftsman C3 set up as well. It's a decent drill and they now have the Li-ion battery packs available for them (which I'll upgrade to as my ni-cads die). I found a kit at the flea market for $64 that had a drill, fluorescent light, vacuum, jig saw, trim saw and a bag. I already had the drill/driver set with a charger and 2 batteries so it was a gloatworthy find. I still want to add the right angle drill and the recip saw to my collection.
                -=gos=-
                If it ain't one thing... It's 12 @#$%ing things!
