Dual BT3100's
  • themachine
    • 140
    • Cincinnati, OH
    • BT3100, General Intl. 220
    Dual BT3100's
    I have the opportunity to add another BT3100 to my rather crowded garage workshop for $75. It seems to be in very good (lightly used) condition. Is there a good reason to do this other than it is inexpensive? I am thinking, for instance, about using this strictly for crosscuts, although I have a RAS that works well, or maybe mounting a dado so I don't have to screw around with throatplates and guards all of the time. And in a small space, how would you arrange these? To support each other outfeed wise, side by side, or not at all related? Thanks for the suggestions.
    use rail joining hardware usually used for extension rails to join the two machines together side by side. This has been called a Frankensaw by previous dualers.
    This will give you stwo saw, one for ripping and the other for crosscuts or dados as well as a 60 or 70-inch rip capacity.
    you might check the FAQ
    • bfrikken
      • 727
      • Michigan, USA.
      • BT-3100
      Just what Loring said, you can set one up as a dedicated dado saw and, it also gives you the "extras" as backups for everything. Long rails, extra motor, another SMT.
      • os1kne
        • 901
        • Atlanta, GA
        If I were doing it, I'd mount them side-by-side to a base unit that had a couple of shelves or drawers and dual-locking casters. I'd dedicate the RH saw to dados, (but if I had a RAS, I'd probably use it for most dados). By going side-by-side, you can connect the rails and extend the rip capacity. Some people have done this already, but I suspect the images are no longer available.
        Good luck! Post pics if you do it.
