Any Body Bought/used These?
I haven't used those specific ones but I have used the ones that look pretty much the same that I got from Ollie's (discount store). They only lasted one use for me. I squeezed each of them one time too many and they don't work any more... I do have strong hands so maybe I just overdid it but it didn't seem like I applied that much pressure. -
I bought a couple of those from HF and have to say that they are no where close to the quick grips. Biggest problem is low clamping power compared to others I have.Joe
"All things are difficult before they are easy"Comment
I'm fairly sure those HF clamps are the ones many people say should be avoided.
If you only want the 6" length and can stand a lighter clamp with a shallower throat depth (about 1-1/2"), Rockler still has their closeout sale on a two-pack of Irwin Quick-Grips for the racehorse price of only $8.99.LarryComment
I bought some a few months back and under any sort of pressure the body expanded and eventually cracked.... I use tin snips everyday so my hands are pretty strong and it was cold out... excuses excuses
... I just bought a four pack of irwin 6" at lowes for $20...
I have a pair of clamps similar to that shown. I broke one doing a glue-up. Time to scramble and get the pipe clamps out. The handle of my clamp is made in halves and can be easily unscrewed. There are two bosses on the inside of each half that hold a 3/16" round pin that the handle pivots on. The bosses sheared off on the inside allowing the pin and handle to fall out. I drilled two 3/16" holes using the remnants of the bosses as a guide and installed a 10-32 socket head bolt with a nut on the end with thread locker to keep the nut on. I used a bolt long enough that there was an unthreaded shank so the handle did not pivot on the threads. Works like it did before.Comment
I checked those clamps out at my local HF and decided those were one of their items that I would be avoiding as the construction seemed very shoddy and didn't seem like they would hold up very well. Their quick release bar clamps however are awesome.Comment
I agree that those HF ratchet ones are to be avoided as they don't hold well. But the bar clamps (34387 and other sizes) are quite nice. In fact, the current Fine Woodworking has an article with a picture of Michael Fortune using a whole bunch of that kind of HF clamp for a curved lamination.AlanComment
HF clamps?
That one you show in the picture....ain't worth much in my opinion.
I have a couple of those same import type from Big Lots a couple of years ago...squeezed them too tight and broke them in half....weren't worth repairing either. I like a heavier duty clamp that will stand up to what I put it thru....the Irwin brand clamps cost a little more but work better also.
eezlockComment
