I decided to try WD-40 to clean the blade from my MS. The blade was not in bad shape, but I wanted to try it. I gave it a good shot of WD-40 on both sides of the teeth, then let it set for over 12 hours. I can't say the WD-40 didn't work at all, but it's effectiveness was minimal, IMHO. Way too much elbow grease needed. I rinsed and dried the blade, then gave the teeth a shot of Simple Green, diluted. After about 10 minutes, it was an easy task to bring the blade back to looking like new.
Now I took off the TS blade, which was in about the same shape as the MS blade (not bad). Gave it a shot of Simple Green, diluted. Had lunch. It sat about 1/2 hour. No problem getting it cleaned without much elbow grease. I used a brass brush on both blades.
but can you please tell me what is Simple Green ??? sorry but thank you , Jemmy.
