HF makes two 23-g pin nailers ... one with a contact safety and one without. Mine (#93656) has a contact safety.
I (think) that I want to remove the safety. Anyone done it?
I removed the Safety Cover (45), and the Safety Spring (49), then replaced the cap screws to hold the Safety Guide (50) in place. I did not remove the Safety (48) yet because it is welded around the body and must be cut off.
Here is the diagram ...
http://www.harborfreight.com/manuals...3999/93656.pdf
The pinner shoots just as well without the safety, but it is much easier to position. Although the tip may be prone to bending since it is not reinforced by the thickness of the Safety Cover and Safety.
I can replace the safety at this point. If you think that there are no problems (other than shooting a pin through my finger), I'll cut off the safety and not look back.
Don't want to ruin my $16 investment!
Thanks,
- Lonnie
Thanks,
- Lonnie
I only paid $15.99 for mine.
Black wallnut
