Wireless starter for a gas generator?
    My dad has a cabin with a gas powered generator in the tool shed. He's got
    to trek out there in the morning and at night to turn it on/off to power the
    house. As a convenience, I was thinking a remote starter for the generator
    would be a cool upgrade. They make them for car engines so do they have
    one for this application? He also has 2 deep cycle batteries that we later
    plan to use to provide light via a 12V lighting circuit rather than running the
    generator to run the lights. These batteries could power the starter.
    I believe it's a Yamaha. If there's enough juice in the battery, a turn of the
    key is all that is needed. If he's been away from the cabin for a while, then
    he has to pull the chord like a lawnmower. Additionally, after the generator
    is on for a little bit, we also manually flip a switch on a 240V circuit to run
    the well pump.
    Please let me know.
    Thanks, Paul
    you don't need a wireless starter, just parallel a wire run to the starter switch and run it into the house since everything is stationary and not going anywhere.
    Put a momentary switch in the house.
      That'll get it started, but you may need additional circuits to enable the starter and to shut the generator down.
      • reddog552
        • Dec 2006
        • 245
        • Belleville Il.
        • Bt3000
        remote starter
        http://www.yamaha-motor.com/outdoor/...65/detail.aspx
        The bitterness of poor quality lingers long after the sweetness of low cost is forgotten!
