Some questions on drill presses...
  • Rob25
    • Dec 2006
    • 61
    • UP Michigan
    • BT 3000
    I am looking to buy a floor drill press, but I am unsure if there is a difference in power between the .5 horsepower, and the .75 hp. I know there is a difference, but is it noticeable? I plan to use it for mostly woodworking, and the occasional metal work. Is the .5 hp plenty, or should I be looking at a 3/4 hp press? Thanks.
    Rob
    you bet there is a difference.
    A more powerful motor will be able to turn those bigger bits - large 3" forstners or rosette cutters or beam cutters.
    A weaker drill press will stall out, cut slowly and burn the wood.
    If you are not going to be cutting the bigger cutting bits over 1/2" or 1" then you don't need the power.
    Why are you getting a bigger drill press?
      Mine has a 1/2 hp motor but the limitation is the small v-belt. It slips long before the motor would stall. It has a lot of speeds, however, and only one set of pulleys so I live with going slower with large bits. The biggest limitation is with large hole cutters. It has always been able to do what I wanted it to, in wood or metal, but I sometimes have to go slow.
