Radial Arm Saw Disc Sander Attachment
  • kajendo
    • 29
    • Hope, British Columbia
    • Craftsman 10" 27413 Ryobi SMT
    Does anyone have a Radial Arm Saw Disc Sander Attachment for sale or has anyone seen one at a suppliers. If I can find a left hand thread union I may be able to make one.
    Thanks in advance
  • Popeye
    • 1848
    • Woodbine, Ga
    • Grizzly 1023SL
    I can't remember if you guys have Sears online access up there or not but, http://www.sears.com/shc/s/p_10153_1...Name=Table+Saw. Pat
      • 22109
      as Popeye points out, there are a number of flat, 10" disks with a 5/8" arbor hole designed to be used as sanding disks in a 10" table saw, there's no reason they should not work equally well for a RAS.
        Popeye has a good idea. I have seen a sanding disk mounted in a RAS. He used it to sand the ends on mitred corners to a perfect 45 degree angle.
        • bmyers
          • Jun 2003
          • 1371
          • Fishkill, NY
          • bt 3100
          If one wanted to sand a shop built RAS table flat, one would need the flat screw on type sanding plate. Jim didn't mention what he was planning on doing with it.
            • 22109
            Bill, he wasn't wanting to sand his table flat, he wanted to use the RAS as a disk sander.
            • kajendo
              • 29
              Sears Canada tool selection pales in comparison to your Sears.
              At one time there was a sanding attachment available without an arbor hole. I imagine that it is no longer available because of the availability of the stand alone disc sander.
              I am getting the ole RAS back in shape for cross cutting and would like to use the Radial Arm to sand the roughness off its own cutting surface.I am inspired by the knowledge on this site and now use a Sears BT3. I am an avid reader of all posts. Allthough I do not contribute any knowledge, I feel as though I am always welcome around the coffe pot.
              Last edited by kajendo; 11-15-2007, 11:23 AM. Reason: trying to splain myself better
              • kajendo
                • 29
                Bill that is exactly what I am looking for. Any ideas on availability?
