I am so busy with my daughters softball I have not had time to setup my HF dust collector (it is collecting dust on top of the box right now). I plan to add a Wynn Filter but have not had time.
I can see where the tie down bolts could be a PITA when you want to remove filter. Here is an idea that might work. Buy some cleats at the BORG and attach to sides of collector. Use carriage type bolts to attach so the rounded head is on inside. Buy a ratching tie down strap and just put it over top to hold it down (I wonder if you tighten on it too hard could you crush filter?) If needed you could put a 2nd strap on it 90 degrees from the 1st one.
Having not seen the filter or studied my dust collector I not sure if this would work. Anyone have any thoughts? Here is my crude sketch.
