How often do you "deep clean" your power tools?
  • Alex Franke
    • Feb 2007
    • 2641
    • Chapel Hill, NC
    (Pardon the typo in the title (and the poll)! -- can't figure out how to fix it!)
    "Deep clean" here implies things like disassembly, scraping, and scrubbing... not just blowing or vacuuming off the visible dust. =)
    121
    After each use - compuslively
    3.31%
    4
    Daily
    1.65%
    2
    Weekly
    0.83%
    1
    Monthly
    6.61%
    8
    Semi-Yearly
    12.40%
    15
    Yearly
    3.31%
    4
    When I think of it
    32.23%
    39
    When it stops working properly
    32.23%
    39
    Never
    7.44%
    9
  • maxparot
    • 1421
    • Mesa, Arizona, USA.
    • BT3100 w/ wide table kit
    I find if you take a few minutes to clean them when your done each day tear downs are a very rare thing. Vacuuming even using a brush while vacuuming doesn't get tools very clean. On the other hand tools that can handle being blasted with high pressure air tend to get clean really quickly but you are generally poluting your environment with fine particles so a mask is a good idea.
    Opinions are like gas;
      • 2812
      Funny you should ask!
      Actually, at the end of each work session, I take the vacuum and blow out as much sawdust as possible, and then wipe down the cord as I wrap it up. At the end of the project, I use a damp cloth to wipe off the outside of the tool and the cord. That's it.
      On the stationary tools, I pretty much do the same things, except that I wipe down any hardware, exposed steel with oil or suitable protectant like wax.
      I had a bunch of tools that I purchased back in the 60's and 70's. Used them occasionally for house projects and repairs, but for the most part they sat in a humid basement for the last 20-30 years. In 2003, when I retired, I took a week to dig them all out, disassemble them right down to the armatures and thoroughly clean out the clumps of sawdust, mold, and dead spiders. Relubed everything and put it all back in service. Surprisingly the only replacement I had to do was the spring steel backing plate on the belt sander which was a bit ragged on the edges. Other than that, everything looks good and runs fine.
      I was a bit embarrassed though to think I had neglected them for so long. Henceforth, the new stuff as well as the old, gets the previous stated once over at the end of every use. I might also add that new tools come in nice cases, and the old case-less tools, get bagged. Once I have time for a shop, things should be better all the way around.
        You need another choice in your poll: one titled "When I think they need it"...
        • charliex
          • 632
          • Spring Valley, MN, USA.
          • Sears equivelent BT3100-1
          I voted Semi-annually but I agree with Uncle Cracker "When I think they need it"...
            Voted 'Monthly' but didn't read your expanation first. I was thinking of blowing everything out good and that was the closest.
            When they need it is more appropriate.
              The only thing I do preventative maintenance on is the BT3100. Even then, I usually wait until the dust doesn't seem to be going down the DC hose or the raise mechanism seems a little stiff.
              • mschrank
                • Oct 2004
                • 1130
                • Hood River, OR, USA.
                "When it stops working properly"
                Case in point: This weekend I removed my Bosch 1617 router from under the table where it usually lives. Turned it on to make one pass and switched it back off. Went to turn it on again and...nothing. Took the top cover off, removed and disassembled the switch to find it PACKED with sawdust. Blew it out, reassembled and everythings great. Well, except that I put the switch back together backwards so "on" is now "off"
                Even though I should probably keep my tools cleaner, I don't think I would regularly take the router apart to clean out the guts...seems that would eventually cause more wear & tear than the occasional necessary disassembly.
                • Jeffrey Schronce
                  • 3822
                  • York, PA, USA.
                  • 22124
                  Sounds like my logic!
                  • Wooden_Go
                    • Sep 2007
                    • 14
                    • Rocky Mountains
                    I just had to replace the four bearings on my 15 year old 9" x 6" sander last week. It started to sound really bad. It wasn't as terrible a job as I thought but not a routine one for sure. Fortunately I discovered that my 9" sanding disc was cracked pretty badly. The paper itself was holding things together. Interesting.
                    I take my drills apart to clean and lube when they start to operate differently. My drill press, jointer, planer, saws and lathe do get cleaned frequently mostly because I can't see them from the sawdust.
                    At the very least though I try to keep things lubricated. But the sander bearings were sealed and no way to lube them.
                    • Mr__Bill
                      • 2096
                      • Tacoma, WA
                      Hmmm
                      Saw the topic heading and one work came to mind.....
                      Golightly
                      that deep seated groan is coming from those in the know
                        • 3126
                        "Deep Clean" your power tools?
                        You use words that make no sense to me.
