Ok so I picked one up this morning. First of all, is it supposed to come with instructions? 2nd are the hands supposed to be in the zero position? If so, how do I zero them in? 3rd, what are the dials for? The top one only move the large hand about 1/4 rotation and the knob at 2 o'clock doesn't do anything.
HF Dial Indicators - any good?
Ok so I picked one up this morning. First of all, is it supposed to come with instructions? 2nd are the dials supposed to be in the zero position? If so, how do I zero them in? 3rd, what are the dials for? The top one only move the large hand about 1/4 rotation and the knob at 2 o'clock doesn't do anything.
Missed your question on the base, I have one but don't use much as they are primarily magnetic holding and I have a BT3000
but i do make a lot of fixtures using dial gauges if you have seen my other posts.
http://www.bt3central.com/showthread...t=height+gauge
No instructions included.
Terminology (not sure of yours) there's two hands, one large one and one tiny one and two scales. Also a bezel which rotates the big scale (to set zero) and a locking knob for the bezel and two tiny limit flags on the bezel.
Hands:large one indicates .001 inches, 100 per turn on the outside scale. As you push the probe in the large hand will spin as many as ten times. 10 x .100" = 1 " total travel.
At the same time the tiny hand will indicate how many .1" full revolutions the big hand made.
To zero the gauge to some arbitrary point, you rotate the bezel which is locked by the knob on the outside of the case about two-o'clock.
This zeros the big hand, you don't worry about the little hand you are supposed to use your toes and subtract.
The two little flags on the edge of the bezel also slide around, you can set limits or reference points with them.
Normal usage:
Assume we are going to measure the thickness of some stock,
we'll use the top of the tabel saw because its iron and very flat.
Put the gauge in a holder, magnetically clamp the holder to the table top.
adjust the holder roughly to put the probe vertical and onto the surface of the table.
you want to set zero with some small amount of deflection( with just a little travel of the probe).
So with the probe touching the table surface, adjust the bezel dial to set zero under the big pointer, the little pointer should be still between 0 and 1 if you did not depress the probe more than a .1" to the table.
Now you can slide items to be measured under the probe (You have to lift the probe by hand), and read off the gauge.
Big hand will read 0-.100, you add this to the number indicated by the little hand x .100 (adjusting for the offset).
Its easy to do once you get the hang of it. repetitive measure of similar items for quaity checking or blade runout seldom span more than a few 10-thousandths so the little hand reading is seldom that important.Last edited by LCHIEN; 09-12-2007, 05:58 PM.
For determining if the miter slot is parallel to the blade you can also make a jig that would clamp to the miter gauge fence and hold the dial indicator. Then move the miter gauge to the opposite end of the blade and read any difference.
Caveat: Gotta make sure your miter gauge is truly set 90 degrees to the miter slot and no slop in the movement. A good miter gauge like an Incra simplifys this set up.
RAGS
Raggy and Me in San Felipe
sigpic
HF dial indicators?
Paul, I have one of the HF dial indicators and so far it seems to work well for me. If you buy one, you will probably need to buy and additional flat tip to replace the pointed end that comes with it...will make run out measurements,
parallel checks, and some other readings easier to do. eezlockComment
Does HF carry those too? item #?-PaulComment
flat tip contact
HF doesn't carry them, They are about $4 from industrial supply houses but that's 65% of what the gauge costs before you add $5 shipping.
Use a round point contact to measure flat surfaces, use a flat tip contact to measure the height of pointed objects (router bits, saw blades, etc)
MY thread I listed in the last post shows the flat tip contacts and I have an article I can e-mail that tells how to make them.
LCHIEN
