3 PHASE DUST COLLECTOR Question
  • footprintsinconc
    • 1759
    • Roseville (Sacramento), CA
    hi,
    question 1:
    i am thinking of getting a my hands on a brand new 3 phase delta dc that has only been used once. but i dont know what 3 phase motor requires electricity wise. do i have to do special wiring? i have heard of a 3 phase convertor - what is that? i just did some wiring for my hd 60gal air compressor (three wire- 2 hot, 1 ground) is this different than a three phase?
    question 2:
    i already have the delta 50-760. its still brand new aswell. if i can sell mine for about 100, then for an additional 150 i can get this 3 phase delta that looks like the 50-760 but has two filter bags on top, 2 plastic bags at the bottom and four 4" ports on it. is it worth it to get. i dont have a shop set up yet, i usually pull the machines and the dc out to use them. is this new dc an over kill?
    so, what do you all think? thanks in advance for your suggestions and advice.
    regards,
    omar
    Double bags indicate a higher air throughput (measured in cfm's) usually requiring a correspondingly larger motor, hence the 3-phase requirement. Your house power probably does not provide 3-phase service, so you would have to purchase a phase converter unit, some of which have a motor, and others of which use a solid-state variable-frequency drive. You are probably looking at a couple hundred bucks minimum to start. Then you have to make sure your present single-phase wiring is adequate, which might require further expense. It seems like your electrical knowledge is pretty basic, so you would be wise to get an electrician involved, which is further expense, yet. Do you see where I'm going with this?
    Your Delta 50-760 is a good dust collector, and much more suitable to a typical non-commercial power setup. I think I'd pass on the 3-phase monster, although it's also possible you could find a suitable single-phase motor to put in it, but still would have that expense, plus probably some beefed-up wiring for the bigger motor. Some things are better left alone.
    • Tom Slick
      • 2913
      • Paso Robles, Calif, USA.
      • sears BT3 clone
      houses/residental are not usually wired for 3 phase nor is it usually available. residental 220v is still single phase.
      for three phase you need 3 hot wires and a ground.
        3-phase is very rare in residences. And would probably be prohibitively expensive to provide from the power company.
        A three phase converter (you put 2-wire+ground single phase in the input and get 3 wire+ground 3-phase on the output) would do the trick, but you are probably talking a 4 or 5 HP motor and you will need to feed the power converter with sufficient volts and amps to run a 5 HP motor, which means probably a 220V 30A one phase circuit, another costly installation in addition to the 3-phase converter, which itself must handle the power levels.
        you have to really want/need your extra CFMs to want to do this, I would think.
        • Hellrazor
          • 2091
          • Abyss, PA
          • Ridgid R4512
          The phase converter is going to cost more than the dust collector will.
          • ragswl4
            • 1559
            • Winchester, Ca
            • C-Man 22114
            hi,
            regards,
            I think your current DC would work fine in a one person shop. Plumbing and blast gates would set you up to conveniently switch from one machine to another. I doubt you would ever need it to evacuate dust from more than one machine. Its the set-up that i use with an HF DC and occasionally I will forget and have two blast gates open and it still works fine.
            Also I would think that that huge DC would sound like a 747 in a small shop.
            RAGS
            Raggy and Me in San Felipe
            sigpic
            • footprintsinconc
              • 1759
              Thanks!
              well thank you all for your suggestion and comments! this site is definately the place to ask for help.
              you are right, my electrical knowledge is next to none. now that i know that my house wont support it and even if it did, the conversion is pretty expensive, i will just simply stick to my current dc as suggested. i just thought that for such an small addition, i could get a dc that would suck the wood in before it got cut!
              thank you all once again.
              omar
