Instructions for Freud SD206 Dado
  • newood2
    • 600
    • Brooklyn, NY.
    I got the SD206 from Amazon today. The only instructions that came with it was this folded paper insert(shown both sides) that's hardly readable.
    Is there some other place to get a 'how to setup' instruction manual, or this is it?
    Howie
    scan it and enlarge it to print or use an enlarging copier to make a bigger print copy.
    • Lonnie in Orlando
      • 649
      • Orlando, FL, USA.
      Instructions and Shim Spreadsheet
      The instructions that came with my SD206 (ten years ago) are easier to read, but very brief.
      INSTRUCTIONS
      Here is a link to Tom Hintz's site.
      http://www.newwoodworker.com/usngstkddados.html
      SHIMS
      I created an Excel workbook to help determine the shims needed to increase a dado to the perfect width. Zip file attached.
      The outer dado blades plus chippers usually produce a dado that is narrower than you need. Add shims to the stack to increase the width to the perfect size.
      One way to determine the shims needed is to run a dado with no shims. Measure the width. Subtract that measurement from the width that you need.
      The workbook chooses the shims that you need to most nearly fill that difference.
      - Lonnie
      • scorrpio
        • 1566
        • Wayne, NJ, USA.
        ROFL.
        When I got my SD206, I did not even notice it came with instructions. I just took my calipers to all the parts and made a reference sheet to follow.
