My drillpress is running backwards
  • hermit
    • 379
    • Somerset, PA, USA.
    I don't know if this applies to your situation, but its food for thought, especially since you said its not the original motor. When I made my DC, I went to local motor shop to get a used 1hp motor, and found one. I used it for a couple years, with no problems..... until I decided to try and upgrade the power with a new motor. I had a hard time getting the impeller off the original, and in the end I ended up damaging the motor. After replacing bearings and trying everything I could, I bit the bullet and took it back to the shop where I bought it to get it repaired. In the end, they couldn't determine what was really wrong (in made unbelievable screeching noise), but he did tell me he suspected the switch. He also told me that my motor was "an instant reverse motor" meaning it was designed so direction could be changed instantaneously (I guess with the proper set up anyway), and for this reason, the switch would cost nearly as much as a replacement motor, so I ended up canning it and getting a new one.
    I don't know how to fix your problem, but maybe your motor is this type. At least maybe you can research that a little further and find a fix. If you have a local motor repair shop, maybe give them a call.
    Todd
      Some older motors have an anti-reverse pawl that prevents the motor from starting in the wrong direction. If you have this type of motor, that may be the problem, although it should occasionally start and run in the correct direction if this be the case. It's also possible that one of your windings is partially shorted, which could unbalance things in the wrong direction. However, if you have another capacitor, that is the easiest thing to change out and check first.
      • rcp612
        • 358
        • Mount Vernon, OH, USA.
        • Bosch 4100-09
        Originally posted by messmaker
        I wonder what the Matag repairman is up to. Perhaps I should give him a ring.
        I think he's fixing the 2-headed giraffe machine at the toy factory. Haven't seen him since he started that one.
          Some -- not many, but some -- tools, such as lathes, milling machines, and drill presses, are reversible. There's not a switch somewhere that you accidentally bumped, is there?
          • Holbren
            • Oct 2004
            • 709
            • Orange City, FL.
            Don't know how old the replacement motor is but 40-50 years is a long time for a cap with a wet electrolyte.
            Brian
            www.holbren.com
            • messmaker
              • 1495
              • RICHMOND, KY, USA.
              • Ridgid 2424
              I passed on a really nice Drill press that they were selling for $75 at a local pawn shop about two weeks ago. I passed it on in Bargin Alerts. I am really rethinking that decision. Passing up a good deal seems to make the tool gods angry. Duhhhhhhhhhhhhhhhhhhhhhh!
              • phrog
                • Jul 2005
                • 1796
                • Chattanooga, TN, USA.
                Old Shaper Runs Backwards
                When you first noticed that your drill press was running backwards, were you looking directly at it or were you looking at it via a mirror? :-) Sorry.
                I have an old shaper from the fifties. The motor pulley is at a right angle to the spindle pulley. Therefore, when you connect the belt, it is in a loop (3D circle eight) configuration. By twisting the belt, you change the direction of the spindle pulley (by design). Although I've never seen a drill press with this configuration I just thought I would throw this at you in case your configuration is similar and you put the belt on with the wrong twist.
                Richard
                Richard
                  Richard
                  He got it resolved on another forum.
                    So what did the problem turn out to be?
                    • ragswl4
                      • 1559
                      • Winchester, Ca
                      • C-Man 22114
                      #25
                      Yeah, what was the problem? I need to know in case my car starts running backwards. Seriously, would like to know what the problem was.
                      RAGS
                      Raggy and Me in San Felipe
                      sigpic
                        I hate to steal his thread but since 2 days have passed.................
                        http://www.forums.woodnet.net/ubbthr...5&o=&fpart=all
                        • ragswl4
                          • 1559
                          • Winchester, Ca
                          • C-Man 22114
                          #27
                          OK, read the posts on the other site. Now I'm going to ask a dumb question, remember that's OK here.
                          If a black and white wire were reversed inside the motor and assuming that was the input power is it possible that the power plug is not grounded and can be inserted into the outlet in either direction? This would reverse the input power to the motor and if those were the wires that were reversed inside the motor to fix this problem then it may re-occur the next time the power plug is reversed.
                          I am not big on motor theory but I think motors have to be designed to be reversible. If not designed to be reversible and the motor starts running in the opposite direction then something has failed in the motor.
                          I know the problem was resolved but I can't get this outta my head.
                          RAGS
                          sigpic
                          • messmaker
                            • 1495
                            • Ridgid 2424
                            #28
                            It was forsed to reverse as a result of the stall. I reversed it at the point where it was wired to get it as it was in the beginning. I did all that and my neighbor brought me a very nice 1/2 hp Dayton motor that he gave me. I installed it and could not be more pleased. Thanks for all your help. Things just have a way of working out.
                            • messmaker
                              • 1495
                              • Ridgid 2424
                              #29
                              The drill press was not unplugged until after the switch of direction so the plug was not responsible even though it was not grounded(fixed that).
                                I think it was good that you replaced the motor, MM, because switching the wires was probably just a band-aid for a larger problem. Something went wrong in there...
