Used Unisaw
  • droc
    • 16
    I'll find out tuesday. At this point it is going through somebody who was helping to sell the estate.
    • droc
      • 16
      I landed the saw for my original offer. Plus the bonus was the fence and all the extension tables and roller outfeed tables, mobile base are included. He had wanted more for the fence than the saw. He was patenting the fence and it is hooked up to some electronics that read the deflection, etc. He was a miniature model maker and machinest and was obsessed with accuracy. I'm interested in tinkering with that setup.
      Sold my 25 year old delta contractor saw for 400, and with the 50 dollar biesemeyer fence from Lowes, and a 59.99 Forrest WWII blade I just ordered, I think I made out pretty well.
      • droc
        • 16
        Help, we just pulled off the motor cover today. He had told me it was 1.5 hp and convertible to 110 (I don't have 220). It is a baldor 83-651 15.5 amp 3 hp on 230. Does anybody know if this motor is convertible to 110? It would need a 30 amp circuit which is not a problem but 220 is.
        How much does it cost to put in 220?
          Just to make sure you understand (can't tell tone or sometimes even meaning by ones typed thoughts, so don't take this wrong). You already have 220, for instance, if you have an electric dryer, or a/c (electric stove, etc). Do you have any non used spots in your electrical box? (there are dual breakers for some brands, that fit in single spots).
          Do you have proper sized wires, for 30 amp 110 (bigger then 12 gauge)? Those can help you answer some questions, cause cost can and does vary (labor rate, cost of copper at the time, etc).
          If you have an opening, and know the linear distance of the wire run, you could call and electrician and ask for a general price for it. (around here, some electricians I know, call them dryer runs, (most common cause)).
          If I am dumbing it down, I'm sorry. Just used to dealing with some family that are afraid of electricity.
          • droc
            • 16
            No offence taken. I did all the wiring in the basement. My dad is an electrical engineer but didn't want to mess with putting in a 220 line. I realize that 220 comes into all houses, but I think it isn't as simple as adding 110 circuits and breakers to an existing box. If it costs more than the saw, than it is not worth it to me.
              If you did the wiring, then you know it is that simple. Read the owners manual (or if it has a plug, figure out it's amp rating), to get the correct size wire and outlet. Get a outlet box, and run the two HOTS to it. (yes ground to...)
