Router bit for cutting box bottoms?
    Within the last few months I saw a router bit advertised as ideal for cutting grooves for bottoms on finger-joint/dovetail boxes.
    It was essentially a slot cutting bit with a number of different sized pilots (to control the depth of cut). You assemble the box with a clamp (no glue), and then run the bit around the inside of the box.
    Then you cut a bottom, round the corners, and assemble everything with glue.
    Anyone know who was selling this?
    • 22106
    MLCS has slot cutter bits with bearings, you can change the bearings if you want. Not advertised as box bottom bits, but #7661 should do nicely (1/8" slot, 1/4" deep).
    http://www.mlcswoodworking.com/shops...s/bt_slot.html
      I'm almost certain it was Rockler, but they no longer carry it and have no info on it. I emailed them a few weeks ago and they weren't any help at all. If you find one please let me know.
      • MikeMcCoy
        • Nov 2004
        • 790
        • Moncks Corner, SC, USA.
        • Delta Contractor Saw
        They are on the pricey side but I got mine from Lee Valley
        http://www.leevalley.com/wood/page.a...168,46176&ap=1
          Those are the right ones, but man are those pricey, and for 1/4" shanks!
            Unfortunately I wanted to use these for smaller boxes w/ 1/4" thick side walls. The one you mention comes w/ a 3/4" bearing, and I suppose I could try to find a 1" bearing, but I don't see any at their web site.
            Also, I wonder if I would be asking for trouble anyhow because the larger radius of these slot cutters may have trouble getting into the corners.
            • MikeMcCoy
              • Nov 2004
              • 790
              I thought they were high when I got them but after several projects, I'm not considering them too far out of line. I don't know enough abougt bit angles and such but they surely cut a smooth groove with no problems. I've tried that technique with regular slot cutters with varied success.
                Thanks Mike, I ordered a set. I'm sure they will come in handy over the years.
                  Whiteside makes the rounded bowl/box bottom bits here:
                  http://www.routerbits.com/cgi-router...75597_16880+16
                  I got my from woodworkers supply about 10 / 12 years ago but they don't have them online now.
                  http://woodworker.com/
                  OHH, Just re-read your post. That wasn't what you were looking for.
