I've been woodworking for years, but I have a rather rookie question; when cutting a piece on the TS, should the waste (thin) or the finish portion be next to the rip fence?
Dumb question?
As a general rule I have the waste to the left of the blade, however it is always safest to have the widest piece between the fence and the blade since thats where your hand is. Less than 6 inches wide I always use a push stick. If I am cutting large panels, it doesn't really matter, do what's safest.
RAGS
Raggy and Me in San Felipe
sigpic
whichever is most convenient. I don't let the target piece or leftover piece dictate how I'm going to cut it. It'll be just as straight and clean a cut on either side of the blade.
Evening Woodrow...
when cutting a piece on the TS, should the waste (thin) or the finish portion be next to the rip fence?... Woodrow
I assume you are referring to ripping since you didn't specify.. since on a cross-cut the fence shouldn't be on the table. On a rip cut... IMHO it would not make much sense to go to extensive lenghts to set a fence to exact (and even then I measure twice by flipping a square over) ....... and then even consider putting the waste side between the blade and fence. Too much sub-traction for this ole country boy. ha.. ha...
Regards from L'ville...Last edited by Guest; 05-25-2007, 09:06 PM.Comment
Amen . . its that pesky blade thickness issue.
And, as I used to tell my students, the really dumb question is the one that doesn't get asked.
Regards, SteveComment
LCHIEN
