Killed motor on Craftsman 21706 Jointer?? Any Help
  • NJFrank
    • Jun 2003
    • 101
    • NJ, USA.
    Just when finishing edge jointing a bunch of boards the motor died. Checked the belt it's attached, took the back off and can rotate the drive pully to the cutter head.
    When I press the on button it's makes a grrrrrrrrr sound, and doesn't turn. I'm going to pull the motor, does anyone have suggestions on what to look for?? It sounds like it's stuck, if that makes sense.
    Thanks
  • eezlock
    • 997
    • Charlotte,N.C.
    jointer problems
    Might want to check the motor brushes, bearings, electrical contact switch
    inside...these are the most common problem areas in most electric motors.
    If you can't find the problem...a good motor repair shop should be able to
    diagnose and fix it cheaper than buying a new replacement motor. eezlock
      • 21971
      Thanks
      Did it die while running or did it just not start one time when it was off before?
      One possibility is that the starting capacitor or the centrifugal switch died.
      That's consistent with the motor just not starting one time (as opposed to dying while running) and making a GRRR noise but not starting.
      Start it and give the pulley a spin being careful not to catch any fingers anywhere) and see if it runs. If it does then the starting cap or centrifugal switch is bad and should be a moderately easy fix for a DIYer.
      • NJFrank
        • Jun 2003
        • 101
        • NJ, USA.
        Thanks EEz and Loring,
        I'll try giving the pulley a spin to see if it catches, if that doesn't work I'll take the motor out and see if I can open it and look for anything obvious.
        Thanks again
