TS sanding disk question
  • final_t
    • 1626
    Since I don't have the space (let alone the money) for a drum sander, and while I have the planer, jointer, belt sander tools, would a sanding disk for the table saw be worthwhile, or just a waste of money and asking for trouble? Thoughts, suggestions, etc?
    some statements here indicate its OK if you use it and a BT3 with a speed controller.
    http://www.bt3central.com/showthread...ing+disk+table
    • Jeffrey Schronce
      • 3822
      • York, PA, USA.
      • 22124
      If one subscribes to the theory that using drum sanders in DP is bad due to adverse pressure on the machine, wouldn't one have to acknowledge the same for sanding disk in TS? A sanding disk seems like a worse idea than using sanding drums in a DP.
      • geeoh
        • 80
        • Mid Maryland
        • Delta Contractor
        I have a sanding disk that I bought 5+ years ago from Sears (under $20). I have used it once and it did a good job putting repetitive rounded corners on a project. I used the miter gauge of the saw which was very handy, plus the saws nice big flat surface. The biggist disadvantage is changing from blade to sanding disk and back. Jeff makes a valid point concerning adverse wear on the saw.
        • vaking
          • 1428
          • Montclair, NJ, USA.
          • Ryobi BT3100-1
          This question was discussed and the conclusion was that it was doable if you slow the speed about 3 times. I may also add - there are 10" and 8" diameter sanding disks. It might make sense to use 8" disk - this way you may have to reduce speed less and the system will be more stable.
          http://www.amazon.com/8-CALIBRATION-.../dp/B00004RK0I
          The link may be a bit confusing since title says 8" but picture says 10', Freud makes both. I don't know about availablity of sanding paper in 8" diameter size. The concern about side load on a table saw or a drill press - I would disregard it. Just like on a drill press there are accessories specifically designed for use on drill press that create side load (circle cutter) I believe that on a table saw cutting wood with feather board will create side loads. Sanding requires light pressure or you will burn wood. I think table saw will survive occasional use as a disk sander. If you need a lot of sanding - you better get a proper tool.
          Alex V
