PC 691 router good for router table?
  • smorris
    • Apr 2003
    • 695
    • Tampa, Florida, USA.
    I have my dads PC 691 router and I'm planning on mounting it on my 3100 router bed. According to the specs it is a 12,000 rpm router. I'm planning on trying to make some raised panels for my sons aquarium stand and am wondering if this router will work adquately (sp). I understand these need the slower speed anyway. For general purpose use will it perform ok with the slower speed than a normal 20,000 rpm router?
    • 22108
    all the references I saw on the web say it is a 27,500 RPM router.
    Fixed speed, D-handle.
    Probably won't work too well for raising panels.
    Besides the BT3100 table opneing is probably too small for a raised panel bit diameter.
    Sorry to rain on your parade.
    • smorris
      • Apr 2003
      • 695
      Thanks for the info LCHEIN. I must have misread something to come up with 12,000. I can always make the panels on the table saw, gives me an excuse to make another jig.
      • whitecobra
        • Aug 2006
        • 180
        • 3 Miles from Disney in Orlando
        • BT3K with most accessories
        As usual Loring is right
        The 691 is a fixed speed 27K unit (have 2 of them)
        The 695 is the same unit only variable speed
        Either will do fine in a table (or the BT) I like mine allot but if you are turning a 3" bit 25K is a ton of speed.
        Look at the 695 instead
        Dr D
        Newest site to learn woodworking, DIY and Home Renovation.
        www.onlineshopclass.com built by woodworkers for woodworkers and supported by the industry so everyone wins
        If you are in the Orlando area contact me lets get together and talk saw dust (or food or anything else you like except sports)
        My wife and I are National Food Judges so we CAN talk food with the best.
        Dr Dave
        • ragswl4
          • 1559
          • Winchester, Ca
          • C-Man 22114
          As others have already said, too fast for horizontal raised panel bits and also vertical raised panel bits. Recommended speed for the vertical bit is 18,000 RPM. Even at that speed its a little scary. Lot of metal going really fast.
          RAGS
          Raggy and Me in San Felipe
          sigpic
          • footprintsinconc
            • 1759
            • Roseville (Sacramento), CA
            raised panels on bt3100 .... possible
            actually, when i made my raised panel for the cabinet doors, i made them on my bt3100. the whole is small. here is what i did:
            i over layer the top with a 1/4" plywood with a hole that was just big enough for the bit to fit into it. the hole was made close to the edge of the plywood so that i could still use the table saw fence. i mounted my ryobi router from the bottom. then install the bit from the top and my doors came out perfect. no problems at all.
            regards,
            omar
