Speaking of Bandsaws
  • L. D. Jeffries
    • 747
    • Russell, NY, USA.
    Just finished putting a 6" extension block on my Sears 12" bandsaw. Got the parts from an outfit on the east coast. Remember one post a while ago that had all kinds of problems putting his together. Other than some minor revamping work on the case side blade protector it went together like a snap! I now have a bandsaw that will resaw at least a 12" high piece of wood. New blades are 93-1/2". Got some new TimberWolfe blades on a recent trip-but thats another story...see "Round the Coffecup"
    Did have to get help putting the top section on as these babies are heavy as sin. So far am as pleased as a pig in s--t!
    RuffSawn
  • Rob25
    • Dec 2006
    • 61
    • UP Michigan
    • BT 3000
    I did the same to mine, adding 11.5 inches in height, and losing half an inch in the throat...
Name:	Shop Tool 3-18-2007 0011.jpg
Name:	Shop Tool 3-18-2007 0033.jpg
Name:	Shop Tool 3-18-2007 0055.jpg
      Originally posted by L. D. Jeffries
      Just finished putting a 6" extension block on my Sears 12" bandsaw.. New blades are 93-1/2".
      Isn't the new blade length 105"?
      • Rob25
        • Dec 2006
        • 61
        • UP Michigan
        • BT 3000
        Naw, it went from 80" to 93.5"...
          • 22033
          14" saw is usually 93" going to 105 with a riser.
          12" saw (this one anyway) was 81 or 80 going to 93 with the riser.
            Oh. Nevermind.
            • siliconbauhaus
              • Dec 2006
              • 925
              • hagerstown, md
              is that bandsaw the hitachi clone?
              パトリック
              daiku woodworking
              ^deshi^
              neoshed
              • grandy
                • 12
                band saw
                I'm a newbee and have a 9" band saw. can the same be done with mine or is it to small.thanks, Grandy
                • Rob25
                  • Dec 2006
                  • 61
                  • UP Michigan
                  • BT 3000
                  Yep, the riser is also a direct fit on the hitachi bandsaw...
                  • siliconbauhaus
                    • Dec 2006
                    • 925
                    • hagerstown, md
                    cool....there's a lot of help on fitting it over at http://cb13f.cpu-etc.com/cgi-bin/yabb2/YaBB.pl
                    which you probably already know
                    パトリック
                    daiku woodworking
                    ^deshi^
                    neoshed
                      • 22033
                      mostly only cast-iron frame 12 and 14" bandsaws with a bolted-together vertical member (e.g. two-piece frame) can use risers.
                      I have never seen any small bandsaws in the 9-10" range be able to take risers.
