Straight edge
  • p8ntblr
    • 921
    • So Cal
    • Craftsman 22114
    Straight edge
    What straight edge do you guys use to set your tables (jointer, TS wings, etc)? I was thinking about the Lee Valley-Veritas Steel or Aluminum. Do you think the .002 tolerance difference between the steel and aluminum is a big deal. Also do you think the 24" will do or should I get the 36"/38"
    Wacha think?
    -Paul
    i think somewhere in the back of my mind we had this conversation before talking about the straightedges from Woodpecker which were even more expensive.
    I don't think that good levels are much less straight; sometimes they can be had for much less.
    see this search result (two articles)
    http://www.bt3central.com/search.php?searchid=263449
    • sparkeyjames
      • 1087
      • Redford MI.
      Starrett 24 inch rule. Accurate as all get out. Lines to 1/64. As straight as they get. Also just about as expensive as they get as well.
      Ok I'm game same post for both threads.
        I think every shop needs a reliable reference straight edge. I've not found anything else that's good enough to be a stand-in.
        I have the LV 38" aluminum model. At the time I got it, I don't think they had the 36" steel model, because I decided I'd rather have more length than a couple more thousandths of straightness. Or maybe they had the 36" steel but I decided the significantly higher price wasn't a good value. In any case, the 38" aluminum has done all I've needed it to do when setting up tools.
        • Imadunatic
          • 217
          • Barryton, Mi, USA.
          holy mackeral, I think the .003 thousands shouldnt be a problem, im not sure I ever set mine up that close, and you have to remember that tolerance is over the ENTIRE length, less then a grand a foot!! I say go for the 50" aluminum, it must be the most accurate as they all have the same tolerance regardless of length, lol
          Good luck with your decision,
          Kevin
          \"Run Varnish, Runnnnnn\"
