Cutting Bolts to Length
  • Bob Bassett
    • 132
    • Shalimar, Florida, USA.
    I use a Dremel Tool with the fiberglass blade to trim bolts to length - cuts down on inventory.
    the other day, I wanted to cut three bolts to the same length. My method didn't work worth a hoot.
    What's the tip fro cutting three 1/4 - 20 bolts to the same length
    Bob Bassett from Northwest Florida
  • mpauly
    • 337
    • NJ
    If you have a bench grinder, double nut the bolts all to the same length and grind the excess bolt down to the nut. The nuts act as a grinding stop and also deburr the threads when you take them off. Just be sure to get a good grip on the bolts with a vice grip or something......the grinder sure can sling them into the far corners of your shop.
    Michael
    • Bob Bassett
      • 132
      Michael
      I'd forgotten all about the double bolt idea. I always put a nut on the bolt before cutting to chase the threads at the end of the bolt.
      The double bolt to mark the length is a great idea. Thanks.
        • 22106
        I usually run a single nut onto the shaft, mark it with a sharpie. then cut with a hacksaw. Run the nut off to deburr, hit it with a file to clean up the ends it necessary.
        • mpauly
          • 337
          • NJ
          I usually double nut them so the nuts don't move (changing the resulting bolt length), but it also provides a larger, more stable gripping surface for your pliers.
            I use double nuts to fix the bolt length, clamp the nuts in a vise, cut with a hacksaw.
            For smaller bolts and machine screws, I use one of those multi-purpose bolt-cutter wire-stripper ferrule-crimper thingies.
            • whitecobra
              • Aug 2006
              • 180
              • 3 Miles from Disney in Orlando
              • BT3K with most accessories
              I follow Lorin (nut with Sharpie) but I use a bolt cutter rather then a hack saw
              The large bolt cutter makes the job seconds
              Run the nut back out cleans up the threads
              Dr D
              Newest site to learn woodworking, DIY and Home Renovation.
              www.onlineshopclass.com built by woodworkers for woodworkers and supported by the industry so everyone wins
              If you are in the Orlando area contact me lets get together and talk saw dust (or food or anything else you like except sports)
              My wife and I are National Food Judges so we CAN talk food with the best.
              Dr Dave
              • scorrpio
                • 1566
                • Wayne, NJ, USA.
                Double nut, clamp in vise, and then cut with an angle grinder.
                • softop41
                  • 470
                  • Plainfield, IL, USA.
                  ditto what Loring said
                  Jerry
                  Jerry
                  • Tom Miller
                    • 2507
                    • Twin Cities, MN
                    Originally posted by LarryG
                    ...clamp the nuts in a vise, cut with a hacksaw.
                    I can't quite put my finger on it, but something about this technique does not sit right with me.
                    Regards and apologies,
                      • 22106
                      it's important to clamp the right nuts in the vice. If unsure, borrow your neighbors. If he screams, it's the wrong ones. Or maybe get Jeff's, if he has any left.
                      • Hellrazor
                        • 2091
                        • Abyss, PA
                        • Ridgid R4512
                        He said "the" not "yours"
                        • niki
                          • 566
                          • Poland
                          • EB PK255
                          I'm with Scorrpio
                          Angle grinder and small bevel on the bench grinder, finito
                          niki
                          • gerti
                            • 2233
                            • Minnetonka, MN, USA.
                            • BT3100 "Frankensaw"
                            Many of those cheap crimping pliers that come with sets of car electric connectors (you know the ones you use to mangle the heck out of a connector before it falls of the wire) have holes in various screw sizes meant to cut screws. The better ones even have a thread in one side so when the screw is backed out the threads are chased.
